Elddis Crusader Storm LED Downlight removal
RogerP1956
RogerP1956 Club Member Posts: 73
First Comment Name Dropper
One of the (8) small (50mm) LED downlights around the sky light has become intermittent. I have not yet found a way of getting these out of the panel that surrounds the sky light. Any suggestions would be very useful as I am getting very annoyed with it flashing at me.
Best Answer
  • RogerP1956
    #2 Answer ✓
    Finally got round to removing my faulty downlight.
    Because of the delicate looking outer trim I decided that I needed something sharp to get under the edge. I removed it, quite easily in the end, by using a sharp wood chisel under its bezel to get it started. just the expected spring clips.
    If you need one they are a:-
    Dimatec 200CA0.4CRIP Mini Pot
    available from Prima leisure.
    Small Round LED Down Light | PRIMA Leisure
    Mine was a loose connection on the crimped spade terminal, all working!!
Answers
  • Fozzie
    Fozzie Club Member Posts: 638
    I had to remove one on a previous Elddis van as the surround had dropped in that corner,I can remember using a trim tool to lever out the LED.It had two flared clips either side.You may have to go in from the side to release the clips if you are still having trouble.
  • RogerP1956
    Thank you for the suggestion. The trim ring on the light is very thin and makes a very flush fit with the panel, I will have to choose a trim tool very carefully to avoid damage.
    Currently away and I do not have many tools with me but I will have a closer look when I get home.
    I have been pondering the idea of applying some Blu Tak to the front of the light to see if they will just pull out.
