Wheel Mover problem
Trailmate
Trailmate Club Member Posts: 9
Not really a problem, just an observation and tip. We've been using the same Powertouch wheel mover quite satisfactorily for a good number of years on what is now the third caravan. When we used it for the last time on the Isle of Mull a couple of weeks ago we had a very noisy graunching noise and it had apparently ceased. However, a closer inspection revealed the real problem. We were on a hard standing made up of quite a course gravel which had got trapped in the tyre treads and upon moving the gravel caused the wheel mover drive spline to effectively brake any movement. By simply reversing the direction of travel just few inches and flicking out the gravel from the tyre treads the problem was overcome. Probably by standing in one position for a week the gravel had had time to jam into the treads. Just DON'T be tempted to use your fingers to clear the offending gravel whilst the wheel mover is engaged and switched on. As I said, just an observation and tip. Cheers
