Location of Water Pump fuse
ArNutt7
ArNutt7 Forum Participant Posts: 1 Participant
Hi I’ve an Abbey Iona 2003 caravan and I can’t find the water pump fuse I am aware there’s a distribution panel with 8 fuses somewhere separate from the road fuses lights etc at the front of the van near the water heater but the others are truly hidden!!!! Any clues??
Answers
  • boyce
    boyce Forum Participant Posts: 1 Participant
    I’ve a Abbey Vougue water heater heats up but after 1st use goes cold
  • eribaMotters
    eribaMotters Club Member Posts: 1,517
    A fairly common place to find a toilet fuse is when you take the flush cassette out, on the side wall inside the void.
    Colin
