Water System
Nuggy
Nuggy Club Member Posts: 521
Hi, My caravan is an old Ace Award Brightstar, first registered in 2003. I have been told that modern touring caravans red and blue semi flexible water pipes have a bigger internal bore.
Can anyone tell me what the diameter used to be, and what the diameter is nowadays?
Nuggy
Best Answer
  • Wildwood
    #2 Answer ✓
    I think most dealers will be able to supply the pipes, but taking a length would help them identify the size of yours.
Answers
  • eribaMotters
    eribaMotters Club Member Posts: 1,485
    edited April 2025 #3
    Is the O/D, outside diameter now not smaller? I recall when fitting a hot water heater to a 2006 van in 2011 that I had to check carefully whether I was needing 1/22 or 12mm water pipe.
    Water Hose for Caravans and Motorhomes | Leisureshopdirect
    Unless you have a micrometre to check the pipe diameter it might be worthwhile checking what appliances you have fitted then look up the technical specification of them.
    Colin
  • Nuggy
    Colin, thanks for your reply, I was under the impression that modern caravans have bigger diameter pipes. I shall continue my research and perhaps call at a caravan dealership to check out modern pipes for comparison. Cheers, Nuggy
  • Nuggy
    A late update, I went to a caravan dealership in Cheadle Hulme, Cheshire and they were utterly useless and positively unhelpful. My score for them out of ten is 'zero.' I have since fixed the leak with a tube of leak sealant costing just under seven pounds.
  • nelliethehooker
    nelliethehooker Club Member Posts: 15,193
    GGlad to read that you have fixed your problem yourself, @Nuggy well done.
