Coachman VIP 460 2022 Bathroom Door Magnetic lock
telecom
telecom Forum Participant Posts: 8 Participant
edited August 2024 in Caravans #1
Hi fellow Caravan owners,
                               Can any one give me advice or practical fixes for a problem i have.
 I have a Coachman caravan  VIP the magnet in the door frame has stopped attracting the magnetic latch in the door on closing so therefore when travelling we have to wedge the door closed,
   On looking on various caravan forums , and talking to fellow coachman owners on site this appears to be a common fault.
    The caravan is a 2022 model the dealership where i bought the caravan from has being in touch with coachman to submit a warranty claim but this has being rejected by them saying it is not covered under the warranty and the caravan is now two years.
The only solution they have is too have a new magnetic catch fitted at a price of £100 personally this is outrageous has i have seen reports where these catches have failed again after a period of time. I think this catch design is poor and not practical why could they have not fitted a normal catch and handle .
So if anyone out there can help i would appreciate your help.
Regards telecom
  • Whittakerr
    edited August 2024 #2
    Hello Telecom.
    I had the same problem with my coachman. I sauced a replacement lock from Kenmore Caravans, see link below. It was £17.35 when I purchased one in April this year. They seem to have increase in cost considerably since then.
    It's an easy job to replace the lock and keep but you do need a very small Allan Key to remove the door handle.
    https://www.ebay.co.uk/itm/174895583188?itmmeta=01J6BZXQW67QXEY762RYA3TGY2&hash=item28b896cfd4:g:4cEAAOSwFUVmE7UI
     Hope this helps.
  • telecom
    edited August 2024 #3
    Hi Whittakerr,
    Thanks for the  reply yes I have seen the locks on the Kenmore site are the magnets any stronger on these than the original one.
    Also I don't suppose you have instructions on how to do.it has my DIY skills are not brilliant.
    Regards
               Telecom
  • Whittakerr
    edited August 2024 #4
    Hello Telecom.
    As far as I am aware the locks are the same as the ones fitted by coachman so the magnets will be similar..
    Changing the lock and keep is quite simple. The keep is secured by two screws.Just remove the screws and fit the new keep. The lock also has two screws that you will see near the latch, but to remove the lock you need to take off one of the door handles and withdraw the square spindle that connects the two handles. To take off one of the handles you need a very small Allan Key, (I had to file down the smallest  Allan Key I had). You will find the Allan screw underneath the handle.
    Once you have the right size Allan key it is very simple to replace the lock. It took me about 15 minuets  in total, including filing down my Allan key to fit.
    Feel free to ask me anymore questions if you need to.
  • KDH12345
    KDH12345 Forum Participant Posts: 1 Participant
    edited August 2024 #5
    I had the same on my  2023 Coachman 855. But I found that by slightly slackening off the two screws, the magnetic latch started working again.  No idea why but it seems to work.
  • telecom
    edited August 2024 #6
    Hi  Whittakerr and Kdh12345,
         Thanks for your replies and instructions which i will try Coachman definitely do not make it easy putting a Allan screw underneath the silver disc very crafty  having to make you use a dealership and expensive price. My caravan is in storage so i will take the smallest Allan key i have and file it down and attempt it.
     I will also purchase a new lock from Kenmore and will definitely be cheaper than the dealership at 60 pound for fitting plus lock at £43 + vat.
    regards Telecom
  • telecom
    edited September 2024 #7
    Hi Whittakerr, KDH 12345.
    Just an update on the above subject. My son has searched the internet for me and as purchased a pack of 6 strong magnets for the pricey sum of £3 . 95. Went down to caravan at storage site yesterday to try them.
      Left original magnet in receiver keep put two new magnets together obviously opposite poles together. The new magnets fitted perfectly in the keep, closed the door and the catch held in the receiver tight, operated handle and the catch retracted back into the door. Repeated the action and it held tight.
    The test will be when we take it on the road at the end of this month hopefully it will hold if not it will be a new replacement lock from Kenmore  caravans, also managed to find the right size Allan key to fit so no filing required.
    Regards telecom
  • telecom
    edited September 2024 #8
    Hi Whittakerr, KDH12345,
    Further to last post being out with van this past week the toilet door has held fast whilst travelling with the above fix using the magnets hopefully problem solved.
    Regards Telecom
  • Whittakerr
    edited September 2024 #9
    Hello Telecom.
    Thanks for the updates. (sorry I missed your update on 2/09/24). Any chance you can provide some details on where your some got the magnets from, for that price I'll get some just in case my new lock fails.
  • McH123
    McH123 Club Member Posts: 3
    edited November 2024 #10
    Hi Telecom
    I am new to "Posts" so please forgive me if I am not following the correct format.
    I am having the same problem with the magnetic bathroom door catch failing after a few months.  My caravan is still under warranty and will be having its fourth magnetic catch fitted at the next service as the door will not stay closed.
    Would you please send me the link for the magnets you bought.
    Regards
    McH123
    edited November 2024 #11
    McH, it doesn’t look as if Telecom has visited the forum since his last post above so may not see your request.
    I’ve seen packs of magnets on Amazon so it might be worth a look.
  • McH123
    edited November 2024 #12
    Hi Tinwheeler
    Thank you, I will give Amazon a look.
    Cheers
    McH123
  • MJSM
    MJSM Club Member Posts: 4
    Magnetic Door Catch
    I had similar problem to above on Bailey Grande Lisbon. In this mid bathroom arrangement the toilet door doubles as a door separating the rear bedroom from the forward accommodation. The gap between door edge and the door frame at toilet, was much greater than gap when door in closed across cabin. When towing with door in closed position to toilet, the door latch failed, with resultant damage to the magnetic lock with a swinging door whist in transit.
    In my opinion this is just down to shoddy workmanship by Bailey (the TV support bracket is fitted 2 degrees off vertical for example). My fix to the problem is as shown in the attached photos using a timber strip to close the gap in between door and door frame. Replacement door latch mechanism and catch housing supplied by PRIMA at reasonable cost. A webbing strap to secure door, also supplied by PRIMA (as used for sliding doors, and gas hob cover) was fitted for additional security when towing.
    I am not sure how many magnetic door catches are in use, but thought it worth adding this as a possible solution for those who may have similar problems.
  • McH123
    Thank you MJSM.
    With my caravan, the door when closed and the frame are only approx 3mm apart. The magnets in the catch and the receiver are just too weak to activate the mechanism.
    I am considering fitting a conventional catch, the problem is the spindle and the catch are not on the same center line. So I think it will look like a bodge job. At the next service the van will be having its 4th catch fitted, FOC at the moment. Why Coachman could not use a conventional catch beats me.
    Regards
    McH123
  • Spanna
    Spanna Club Member Posts: 1
    Name Dropper First Comment
    Do you have details of the magnets you got, as I would like to try this to see if it will help as we have the same problem.
    Many thanks
    See my post up page, Spanna. I don’t think anything's changed.
  • Keybored
    Keybored Forum Participant Posts: 1 Participant
    Hi Folks
    I have had the same problem. The first time that I fixed it I found a very helpful post on another forum where someone had taken the door lock apart. From manufacture the unit has both magnetic latch and physical lock mechanism but the coachman doesn’t utilise the lock mechanism. The lock moves with vibration and stops the magnetic latch from working! It is very simple to remove the physical lock components and when reassembled everything worked perfectly for six months or so. The second time it failed I took it apart again. The latch has three magnets. One in the doorframe keep, one in the end of the lock piece and a third in the lock assembly which holds the lock in the open position, presumably this is a smaller magnet allowing the keep to overcome it. I found that the magnet in the lock had worked its way partially out of the lock towards the rear magnet thus moving it further away from the keep magnet so that it no longer worked. I pushed it back into place and everything works just fine again. Hope this helps.
