Water drip from freshwater tank
Leach48
Leach48 Forum Participant Posts: 1 Participant
edited July 2024 in Caravans #1
There are two pipes from the hot water tank that exit the underside of our caravan through a hole in the floor. Not the drain pipe which we empty the tank through.
One of the pipes is dripping hot water. I've checked and it is pipe 2 (red arrow in my photo), which is attached to 'the red breather valve'.
This causes the pump to switch on/off momentarily every few mins unless we turn the pump off.
Any idea what is causing the water to leak from the tank and how we can stop it?
Thanks
    KjellNN Club Member Posts: 9,028
    edited July 2024 #2
    We had a similar problem and to fix our leak I had to fit a new pressure relief valve, which is contained in that red thing.  It was an easy job, but before doing it, let the boiler cool down and then release the pressure slightly by opening the drain valve for a short time.
    It seems Alde no longer sell parts direct to the public, so you will need to order up the correct part from a retailer.
  • old ludlovian
    old ludlovian Club Member Posts: 133
    edited July 2024 #3
    Had similar problem check all pipes and push them back to gether that’s the beauty of the connector pipes just keep searching you will find it
  • jennyc
    edited July 2024 #4
    We had a similar problem with our pressure relief valve this summer. It’s a different configuration to yours but the same function. Amazon sent a replacement to our campsite in Spain.
