Too much hot water
MrsV
MrsV Club Member Posts: 1
edited March 2024 in Caravans #1
I have a trauma heating system in my caravan and am out for the first time this year. My hot water is turned off on the heating control panel yet I have some very hot water coming out of the taps. Can anyone help me to turn off the hot water please?
  • nelliethehooker
    nelliethehooker Club Member Posts: 15,156
    edited March 2024 #2
    I don't think that you can turn off the hot water if you are running the heating in your caravan, although I have been known to be wrong. laughing
    DavidKlyne Club Member Posts: 14,607
    edited March 2024 #3
    Might need to know a bit more about the system you have and age? If you have  a Truma set up with a CP panel the heating and hot water are separate. Is it possible the hot water has been left on by accident? Even on the old Truma systems (round dials and lights) it was possible to control heating and hot water separately.
  • TobyLeeds
    TobyLeeds Club Member Posts: 151
    edited March 2024 #4
    You could try turning the blown air fan off to see if that helps
    edited March 2024 #5
    In some systems the hot water tank surrounds the heater element so if the heating is on, so is the hot water but I agree with David in that we need more info.
    edited March 2024 #6
    The Truma combi boiler in our MH will produce reasonably hot water, after a period of time, with just the blown air  heating on. Of course if the heating turns off the water will gradually cool unless water heating is separately selected.
  • richardandros
    richardandros Club Member Posts: 3,151
    edited March 2024 #7
    We have the Truma Combi 6e in our van and I've noticed that regardless of whether the hot water is turned on, the water gets warm with just the heating on.  It's particularly noticeable if you're running on gas - when it gets really hot relatively quickly.
    I don't see it as a problem and don't understand why the OP wants to 'turn it off'?
    What I will say, though - is that it's best to run the heating / hot water on gas whenever you can.  I know to my cost that with, admittedly, fairly heavy usage of our van, the electric heating elements only last about two years and when they failed again this February - almost two years to the day after they were last changed - it cost me over £700 for them to be replaced.
  • Rufs
    Rufs Club Member Posts: 4,105
    edited March 2024 #8
    Wow!!!£700, cant beat the old system simple cylinder gas/electric, electric is just a simple element inside the water cylinder, ours failed in Spain a couple of years back 30 euros for engineer to replace, never used the gas, heating in caravan is via gas/electric fire blown air works just fine,
  • Takethedogalong
    Takethedogalong Forum Participant Trusted Posts: 18,176
    edited March 2024 #9
    Our Truma heating system in our MH, gas/electric is 22 years old. We have had MH 10 years now, never had a problem with heating or hot water. Work separately. As far as we know (got lots of paperwork about it’s previous life) it’s never had a problem. We use it for both heat and water, and use it daily as we often off grid.
    Hope the OP gets their issue solved, and it’s not expensive.
    edited March 2024 #10
    I agree, between Truma and van designers they have made things unnecessarily expensive. Truma will now only sell a complete heating unit, rather than the elements and Hymer saw fit to shoe horn our boiler into a position where it had to be removed to replace them. Ours lasted 4 years.☹️
    edited March 2024 #11
    I think the problem with costs is that Truma only supply the complete heating cassette and no longer the elements. (I understand these can be obtained by third party suppliers but that is always likely to be a risk?) Truma in Derby will actually carry out  the work if its easier than going to a dealer.
    I am trying to visualise the system mentioned by TDA. If I recall the was a stand alone heater, including fan and a separate boiler, not unlike the current Combi but without the blown air connections. Before that it seemed to be just a Carver convector heater and a Cascade boiler for hot water. I think Carver was taken over by Truma.
  • Takethedogalong
    edited March 2024 #12
    Not far off DK. Stand alone heater, under wardrobe, but there are blown air outlets into bathroom and around living area, so it can be just heater alone, or use blown air as well. Water heater tank is under one of beds. Both work fine either on gas or hook up, and have thermostats.
    Our old caravan has Carver branded heaters. OH has put in a new (to us) heater, again under wardrobe. This works on either gas or hook up, but no blown air system. Replacement water heaters are harder to find, but we have one, but only use it on hook up. Van is 40 years old this year. Our larger van, another Cotswold dating from 1984 had Alde heating. A tall heater/tank system at side of wardrobe, with pipes all around under seats/beds, into bathroom. We didn’t like it, nowhere near as warm as Truma/Carver, took ages to get warm. But you did get warm clothes, most efficient inside wardrobe🤣
    edited March 2024 #13
    In our 2004 Abbey we had a Truma convector heater, which also supplied blown air to a couple of vents. It kept the van toasty warm even on 900 watts. It worked faultlessly on electric for 8 years, when sold it.  The water was supplied from a separate mini immersion heater, which also performed faultlessly.
  • Takethedogalong
    edited March 2024 #14
    Sounds very like ours Steve. Simple set up really, easy to use, easy to fix should anything go wrong. I suppose the more high tech things become, with computers running things, the less reliable, harder to fix and much more expensive things become. Bit like modern cars I suppose. We can hit the MG with a hammer to cure faults, Jeep needs linking up to diagnostics, then your wallet takes a hammering🤨
  • mickysf
    edited March 2024 #15
    Very rarely do we turn the hot water on. When the blown air is on there is enough heat in the combi to heat the water too. It does, however, take a longer time to warm up. We only turn the water heater on in summer when no space heating is required and only then for short periods when hot water is needed. It heats up quickly mind, particularly on gas and, I think, it’s set at 60C.
  • richardandros
    edited March 2024 #16
     Correct David - re the heater elements.  The problem was that if the elements weren't fitted properly (i.e., the fins crimped around the element) they went in no time at all.  Experienced that when the dealer didn't do the job properly two years ago and the elements only lasted a month! Truma obviously had a major problem and that's why they then only sold the elements as a 'kit' which included the elements already fitted into the heating cassette.  That's what was subsequently fitted but they still only lasted two years.
    They've also changed the design of the gas burner and some of the gaskets - whether this will make a difference, only time will tell.
    There was a lot of discussion about this on 'Caravan Talk' and someone had calculated the number of hours an average element would last.  I worked that out against our usage of the van and it equated to about 18 months use - so in one sense, we did well to get another six months use out of it.  It's still absolutely ludicrous, though.
    I agree with Rufs - why can't they be made with a simple domestic-type immersion heater element which costs £20 or so?
    There was talk, some time ago (according to our dealer), that Truma were discontinuing the Combi 6e and replacing it with something more reliable but that doesn't seem to have materialised.
    edited March 2024 #17
    When we are away in the van we don't experience what the OP does as the hot water and heating are always on together. Obviously when its warmer we will just have the hot water on. The only time the heating is on by itself is if we are trying to warm the van up to give it a bit of an airing over winter when the water system is empty.
  • Rufs
    edited March 2024 #18
    "I agree with Rufs - why can't they be made with a simple domestic-type immersion heater element which costs £20 or so?
    because as the years have rolled by more and more caravaners/MH people wanted to walk out of their house into the caravan or MH and have exactly the same creature comforts as they have indoors and these come at a price and some major downsides e.g. trying to squeeze a quart into a pint pot means some stuff is installed into very tight spaces and when it goes wrong you need to take the caravan/MH to bits to effect any kind of repair.
    We use our hot water heater simply because it is more convenient for us to wash up in the van, for heating we have the inbuilt fire/blown air but normally use a blow heater fan sitting on a shelf much more efficient and much eaiser to control.
