Water heater in Bailey Adamo constantly on
Rourkton
Rourkton Forum Participant Posts: 2 Participant
edited November 2023 in Motorhomes #1
The water in my Bailey Adamo 75 4i is constantly being heated despite Truma control turned off. Any thoughts / solutions?
    DavidKlyne Club Member Posts: 14,797
    edited November 2023 #2
    I have a Bailey Alliance which probably has the same Truma CP control panel. Firstly the main motorhome control panel (usually over the hab door) needs to be on for the 12v system, which controls the Truma panel?   Is it possible that the hot water has not been switched off but the Truma control has gone into sleep mode? How are you determining that the hot water is on all the time? Even when off the water will stay hot for some time.
  • Rourkton
    edited November 2023 #3
    Thanks David
    Water was still hot after 24 hrs and having run at least 20l through the system. Truma panel was still operating the cab heating and hot water was definitely off on the panel.
  • mickysf
    edited November 2023 #4
    Just having our space heater on will heat the water to a useable temperature. In fact, for most of the year we rarely if ever turn the water heater on.
  • Kasspa
    Kasspa Club Member Posts: 379
    edited November 2023 #5
    If water was still hot after 24 hours I'd suggest it was still permanently heating it up......
    I have the Truma app on my phone, use it via bluetooth in the van to change any settings if we're sitting, boost heat, water, have even used the timer so it comes on ready for the morning....
    Give it a go, it just may well show you what settings are not switching off.....
    Hth
