Motor mover won't lock into engage
ClubMemberCDF0B80E08
ClubMemberCDF0B80E08 Forum Participant Posts: 1 Participant
edited October 2023 in Caravans #1
Hi.
I'm a newbie. I know very little about the technical side of caravanning but I'm learning. I have a powrtouch motor mover...12 year old. Its a manual spring engagement system using a wrench. It has worked fine until recently. Now it won't lock into the engage position on either side...as though something is stopping it and making it bounce back. I've looked underneath. The bar is not bent, there seems to be a vent pipe in front/ above one of the units but it must have always been there as there is a hole above for it to go into. Am I missing something obvious? Is this a common problem?
    edited October 2023 #2
    That’s one of the most reliable movers I’ve come across and best in the manual version as you have, in my opinion.
    Powrtouch have always been helpful when I’ve contacted them.
    https://www.powrtouch.com/contact/
  • wedgy
    wedgy Club Member Posts: 432
    edited October 2023 #3
    Make sure the gap between the rollers and wheel is 19mm. If not adjust as per the manual  if it is 19mm the lubricate the mechanism as per the manual
  • jennyc
    edited November 2023 #4
    We’ve had our fair share of engagement problems from motor movers over the years. Our cure is to spray WD40 over anything and everything that looks like it might move. Then engage and disengage the mover about a dozen time, followed by a further WD40 coat on anything that looks starved.  Finally wipe the surplus from non moving parts. It’s never failed.
