Diesel in water tank
ScreenName7A1240CE0C
ScreenName7A1240CE0C Club Member Posts: 1
edited October 2023 in Motorhomes #1
Hi everyone,
a couple have rented our McLouis 379 motorhome and have inadvertently put about 12l of diesel into an otherwise fairly full fresh water tank.
They are close to Chichester and are having problems finding anyone who will help them drain the tank and dispose of the contaminated water- they've even tried the council.
Any ideas?
    DavidKlyne Club Member Posts: 14,792
    edited October 2023 #2
    The Council do take hazardous waste but diesel contaminated with water is not listed. What about a local motorhome dealership? This is another service in the area which may be able to help. Whilst emptying the contaminated water is the first step its unlikely you will be able to reuse the tank as I imagine it will be difficult to completely remove every last drop without using some sort of solvent which might have a negative impact on the water system so I would be prepared for the prospect of needing a new water tank?
  • mickysf
    edited October 2023 #3
    They are not the first to do so, I recall a celebrity several decades ago doing the same which was reported in the papers and on TV. A real nightmare I’d guess!
    edited October 2023 #4
    My thoughts also David. Plus I would think the inlet pipe which in ours (top section at least) is ribbed plastic, would also be difficult to decontaminate.
    Tinwheeler Forum Participant Trusted Posts: 24,324
    edited October 2023 #5
    That also goes for the pump and whole system if a tap was turned on. It may need total replacement.
