Lunar clubman display panel problem
ClubMember6A2B506AB2
ClubMember6A2B506AB2 Forum Participant Posts: 3 Participant
edited June 2023 in Caravans #1
  • Anyone had this before? Everything seems to be working just the display gone potty!
  • ClubMember6A2B506AB2
    edited June 2023 #2
    Just wondering if anyone can help with this please
    Tinwheeler Forum Participant Trusted Posts: 24,316
    edited June 2023 #3
    I think you would have had a response by now if anyone could help.
    I suggest you discover the make and model of the control panel on which Lunar have placed their name. You may need to remove the cover to do this or it may be in your handbook. It could be a Sargent, a Nordelettronica or any number of makes. Once you’ve established what it is, you should be able to contact the company concerned.
    edited June 2023 #4
    Assuming this advert is correct, you appear to have a Sargent control panel. Once again, Google is your friend and you may find a lot more info than I have with my brief search.
    Here’s a link to Sargent's technical support.
    https://sargentltd.co.uk/tech-support
