Hot water temperature fluctuations with our shower
ScreenNameF7B3D7266E
ScreenNameF7B3D7266E Forum Participant Posts: 1 Participant
edited May 2023 in Caravans #1
We have a 2023 Coachman 575 and are having water temperature fluctuations whilst using the shower, which gets extremely hot for a brief second and the runs fine for a minute and then repeats !
Anyone have any advice or information as to why would be gratefully received.
Many thanks.
    edited May 2023 #2
    On a new caravan, I’d get the dealer to sort it.
  • Freedom a whitebox
    edited May 2023 #3
    Isn’t it about time that manufacturers started fitting thermostatic shower valves as standard?
    They are available and can be found fitted to statics.
    I installed one in my unicorn 3 as I was fed up either getting scalding or freezing water when turning the water on during showering.
    Its beeping reliable over many years and I believe it saves water as I just turn it on and don't have to mess about trying  temperatures!
  • FBW
    FBW Forum Participant Posts: 1 Participant
    edited August 2023 #4
    Had the same problem with 2023 VIP565. Ridiculous that manufacturers can leave a van with such a safety critical fault. This should have been sorted with the PDI check at the very least.
    Problem easily solved by calibrating the pump. Instructions in manual and whale have a video showing how to calibrate.
