A-class cab (engine) heater
Mr Bounty
Mr Bounty Forum Participant Posts: 17 Participant
edited May 2023 in Motorhomes #1
Hi all,
I have a 2004 Burstner A-class Motorhome based on the 2.8 Fiat Ducato van.
The cab heater is next to useless and blows lukewarm~ish at the very best. If the outside temperature drops then the warmth coming from the vents is barely detectable. It’s the same after 10 minutes at motorway speeds, only cold air comes out. The temperature gauge sits perfectly where it should and never moves. All input is appreciated.
My supplying dealer reckons that this is just how A class vans are because of the larger dashboard area. They’ve had it back twice with no improvement.
    edited May 2023 #2
    If this is the standard Ducato cab heater rather than something fitted by Burstner, I think you’d be better off going to a motor garage rather than a MH dealer.
  • Mr Bounty
    edited May 2023 #3
    I believe it is the Fiat unit, although I don’t know for sure.
    edited May 2023 #4
    Try contacting a few garages, preferably those that do van work, and see what they say.
    Tbh, I’d not expect many dealerships to have much idea about this issue.
    edited May 2023 #5
    edited May 2023 #6
    blocked heater matrix .... ???
  • Kasspa
    Kasspa Club Member Posts: 379
    edited May 2023 #7
    The temperature gauge sits perfectly where it should & never moves.....!
    I trust by this you mean it moves to what you consider to be it's position at 'operating' temperature?
    If so, then I would suggest thermostat is opening/closing properly & any fault is as suggested by DD & Emilys Dad.... air lock/blocked matrix especially considering age of vehicle!
    Have you had a coolant change anytime recently or repair to system, hose/radiator replacement?
