Noise when drawing water
Catsize
Catsize Forum Participant Posts: 73 Participant
edited April 2023 in Caravans #1
We are away in the caravan at the moment and have had no problems for several days. Yesterday, the water pump has started making a noise when the tap/shower is on. It’s the same noise you get when things aren’t quite connected properly - that sort of high pitched buzzing noise. However, the water works fine. We are reluctant to use the water because it sounds terrible for our neighbours. We have bled the system, and it’s made no difference. The caravan is 8yrs old. Could it be a more terminal problem with the pump? Hope not! This noise continues for some time after the tap has been switched off too. It’s a whale system in a Compass Corona 576. Thank you.
  • Mr Bounty
    Mr Bounty Forum Participant Posts: 17 Participant
    edited April 2023 #2
    Check to see if the pump has come loose from its anchor point.
    KjellNN Club Member Posts: 9,044
    edited April 2023 #3
    Pumps do not last forever, and are an essential item, so always a good idea to have a spare with you, is it one in the barrel, or an on board one?
    It sounds to me like the bearing is gone or there is dirt in there somewhere.
