Motorhome Door Frame Lock-Magnum Entrance Security
ScreenNameEEEE70BB1D
ScreenNameEEEE70BB1D Forum Participant Posts: 2 Participant
edited January 2023 in Motorhomes #1
Has anyone fitted Motorhome Door Frame Lock - Magnum Entrance Security Plate on bailey autograph 69-2 ?
    peedee Club Member Posts: 10,062
    edited January 2023 #2
    Not to a Bailey but an Autotrail and I have one on my current motorhome. The usual problem is not enough strength of the panel you are attaching it to. When I fitted mine I reinforce the inside of the panel with a piece of 1/4 inch thick ply square.
    DavidKlyne Club Member Posts: 14,706
    edited January 2023 #3
    On my Bailey Approach I had a Fiamma D Lock fitted which was fine because the bolts went through into a cupboard. On my now Bailey Alliance I couldn't have the Fiamma as the bolts would have gone through into the shower! But they did offer me the Milenco version which was a door frame fitting rather like the lock you have illustrated (not sure if that has a secondary fixing through the wall?) If it's just the into the door frame they had to machine it down inorder for the door to close correctly. See picture below.
  • ScreenNameEEEE70BB1D
    edited January 2023 #4
    Thank you both for replying .
    Diane
