Battery Problems or is it Solar?
andytyneandwear
andytyneandwear Club Member Posts: 118
edited September 2022 in Caravans #1
I have a Bailey Unicorn 3 Valencia with a factory fitted 100w solar panel, a new Banner battery fitted 2 years ago but just lately taking the van off the drive it seemed very sluggish on the motor mover. On checking in bright sunlight the battery seems to be charging at 13.6 volts but switching on the lights (all LED) radio and heating circulating pump (not the heating) after about 30mins the battery voltage drops below 10V still in bright sunlight and the charger shows battery charging ok.  Any ideas?
  • Freedom a whitebox
    edited September 2022 #2
    Check to see that the charge controller is working (flashing light) located above fridge.
    check fuse for solar panel, under bed just before wiring loom disappears through floor
    and the obvious that all connections are tight
    The solar panel  on the Valencia will happy keep two batteries charged, as i plug in my Nissan Navara ( to the spare contacts - second battery) when I’m not using it
  • JollyKernow
    edited September 2022 #3
    Afternoon
    If your battery drops that much in that short a time with only the items you mention switched on, then I'd say it's the battery. The draw by those items would be compensated by the sun on the panel.
    Take battery off, charge it fully at home, then put a multimeter on it 24 hours later. It should read at least 12.6 volts.
    JK
  • andytyneandwear
    edited September 2022 #4
    Lets give it a go, Thanks.
