Bailey Olympus 2011 Truma Water Heater
Mick7491
Mick7491 Forum Participant Posts: 2 Participant
edited June 2022 in Caravans #1
I would appreciate some advice concerning the valve which changes the water supply from external to internal on the Truma Water Heater please. Currently the position is set to pull water from the external supply (see photo) and, in order to change this to the internal supply, it needs to be moved 180 deg in an anti-clockwise direction. However, the blue handle refuses to move and I am wondering if I am doing something wrong. I am loath to use too much brute force and ignorance as I don't wish to damage either the handle or the adjacent plastic pipes. If anyone can suggest where I'm going wrong, I'd be most grateful. Thanks in advance.
    DavidKlyne Club Member Posts: 14,599
    edited June 2022 #2
    Can't really answer your question but as the valve has push fit fittings might it be easier to disconnect and remove it to allow closer examination?
  • Mick7491
    edited June 2022 #3
    Hi David
    Thanks for your reply. I have now managed to turn it 180 deg - brute force and ignorance can be useful sometimes.
    Mick
