Anyone please help me with what water pump I need
ScreenName9AE0A41E0B
ScreenName9AE0A41E0B Forum Participant Posts: 5 Participant
edited May 2022 in Parts & Accessories #1
Hi, i have a Lunar Solar Eclipse 2000 524 model and it says i have a Carver Crystal 3 filter system, I cant seem to find anywhere that have the water pump to fit the outside connection that i have shown in the photo i have added. Could anyone please advise and help what it is/ where could buy thank you. I have already tried WATERMASTER CARVER PUMP HIGH FLOW for TRUMA CRYSTAL II COMPACT SOCKET CARAVAN and that doesnt fit
  • redface
    edited May 2022 #2
    The only thing I can suggest is to go to your nearest lunar dealer and take their advice.
    Good luck and perhaps other club  members who have this type of water input can help you further.
  • ADP1963
    edited May 2022 #3
    Screen Name
                            Because of the year your best bet is a Caravan Breaker there are many around. If possible try and see it before you buy it.
    edited May 2022 #4
    Perhaps change to a modern filter and pump?
  • jennyc
    edited May 2022 #5
    There are two parts to your system. There’s the plug in connector, which you can retain, and there’s the submersible pump which you can readily buy. If it’s 12v anyone’s will work. You’ll need to cut the original one’s cable near the plug in connector and join in the replacement. Soldered joins are best, sleeved with heat sensitive shrink sleeve with, ideally a squirt of silicone sealant introduced into the sleeve before shrinking it.
