Help fitting replacement hitch damper
RHambo
RHambo Club Member Posts: 10
edited May 2022 in Caravans #1
Good afternoon I have bought a replacement hitch damper & looking to fit Al-ko stabiliser hitch back on & not sure is it the first hole or second hole the damper fits through thanks
    edited May 2022 #2
    Have you looked on Alko's website or YouTube?
  • Lutz
    Lutz Forum Participant Posts: 1,695 Participant
    edited May 2022 #3
    When you disassemble the hitch just take a note of which hole the damper is attached. As EmilysDad says, YouTube videoclips are useful. It's fairly straightforward, really. I replaced the rubber bellows on the hitch last weekend, which is a similar job.
  • RHambo
    edited May 2022 #4
    I took it off last week & been waiting for replacement to be sent I have tried YouTube it’s not very helpful same as Al ko web page the damper is inside draw tube so I couldn’t see which hole it was in I am guessing it’s the 2nd one nearest the caravan
