Glueing alloy panel on top of damaged side panel
FasAFaFit
FasAFaFit Forum Participant Posts: 6 Participant
edited May 2022 in Caravans #1
Hi
 The proposal to repair a damaged side panel is to remove parts of panel protruding and cover area outlined in blue with a similar panel, glued on top.
 What are your thoughts about this type of repair - apart from the edge of the glued-on panel being seen at the vertical line at battery box and below the door?
 The glued-on panel would be under the door seal.
 Thanks for your input.
  • eribaMotters
    edited May 2022 #2
    If it is an insurance job it's a cheap way out for the insurance company.
    If it was something you have to repair at your own cost then the exposed edge is something I think I could live with.
    Colin
  • Whittakerr
    edited May 2022 #3
    I agree with Colin but i wouldn't accept the edge of a glued on panel going through the battery box and what looks like an external socket. they will never sit properly flush and will be a weak spot for water ingress. I would insist the panel goes to the end of the battery box.
