Caravan door lock
Muso101
Muso101 Forum Participant Posts: 28 Participant
edited April 2022 in Caravans #1
Has anyone ever fitted a security lock to the door of a Bailey Pegasus 534?  I have searched but cannot find any lock that would fit?  and it seems nearly impossible to remove any cupboards that are fitted around the door area?
Any advice,help,or photos from anyone who might have done this job would be much appreciated!
smile
  • dave the rave
    edited April 2022 #2
    To be honest......why bother......the plastic window catches are the weakest point and any damage would be easily fixed....damage to a door and frame would be costly and a delay whilst new door and frame are delivered and fitted.Obviously in my opinion before anybody wants to argue!!
    edited April 2022 #3
    I agree.
    The only reason I can see for getting such a lock is if it is the Fiamma type which doubles as a handhold/steady support but no doubt the OP has his reasons.
  • dave the rave
    edited April 2022 #4
    wow!
  • Pippah45
    edited April 2022 #5
    I fitted the Fiamma one to two caravans because the dog worked out how to open the door when I wasn't in the van and of course small children could go walk about too easily if parents were asleep - hence Archie's Lock for the older type caravan lock.  I have one of those if anyone wants it - it doesn't fit my newer caravan.  I should add that I only left the dog to go and fetch something from the car but it meant I couldn't go to the toilet block either.  I have a feeling that my new dog could also open the door if she tried so I put the Fiamma handle over if I go to fill the water or other short absences!
  • Muso101
    edited April 2022 #6
    Thank you all for your replies,much appreciated.... seems as the only one available  for the 534 is the Fiamma,so Pippah,if you have a spare one,I will take it,let me know how much you want,and whether you would be able to post it to me?
    Many Thankssmile
  • Pippah45
    edited April 2022 #7
    Sorry Muso I use the Fiamma - but I have "Archies Lock" available so if yours is a fairly new caravan it won't work.  It fitted my Abbey caravan 2010.  Its a plastic cover that stops small fingers or big paws opening the door from inside!  If you send a picture of your lock from the inside I could tell you.  The dealership did try to tell me the Fiamma wouldn't fit but I showed them the one on the Abbey and told them to get on with it!
  • Muso101
    edited April 2022 #8
    Good Morning Pippah,
    Thanks for getting back...I've never heard of an "Archies Lock" before,but sounds good,so I've attached photos as suggested... My caravan is 2010 also.... take carelaughing
  • Pippah45
    edited April 2022 #9
    Sorry I didn't get back to you before - I will have a search and see if I can find it because I am fairly sure that it will work.  If I remember correctly Archie was the grandchild of members who went walkabout in the middle of the night!
  • Pippah45
    edited April 2022 #10
    So far it remains undiscovered but I will keep trying - it was a neat cover that fitted over the whole assembly - maybe a plastic box would do the trick - a Takeaway one or something.
    A question though - are you trying to stop a child or a dog get out when they shouldn't i.e. when you are asleep?  Because that is what Archie's lock does - it wouldn't stop anyone getting in from the outside.  The fiamma does both of those things if I am outside - and it has been a godsend for me adjusting to my new hip to feel safe.
    As Tinwheeler said intruders would find the windows easier to get in by.
  • Muso101
    edited April 2022 #11
    Thanks for your reply Pippah.... perhaps if you do find it,you could send me a photo? and yes it would be for the inside only.
  • Pippah45
    edited April 2022 #12
    I will keep looking - it was just a piece of plastic that fitted perfectly over the whole unit - it wouldn't be too hard to make one with cardboard and tape - so the switch bit is covered over?  Hence my suggestion of a Takeaway type box modified to fit.
