Leaking truma ultra flow pump
Rob31
Rob31 Club Member Posts: 3
edited March 2022 in Caravans #1
I am getting my coachman vip ready for a new season and tried my truma pump with inserting the gun into the housing. When we tried it, there was water coming from the housing. I’m not sure if it’s the O rings on the gun or the housing cracked. Any advice would be appreciated if this has happened to anyone and what did you do to sort it
  • dave the rave
    edited March 2022 #2
    first and easiest thing to do is look at the "0" rings.If they look okay try a little vaseline on them.New rings are a rip off price from a caravan shop so if required try a local garage (take a sample with you)If the housing is cracked the fault will be visible!
