Burstner Solar battery charging.
Simon Taylor
Simon Taylor Forum Participant Posts: 1 Participant
edited September 2021 in Motorhomes #1
Does anyone know if the Solar panel on the Burstner 744 Harmony Line ( 2021) charges both the leisure and vehicle batteries. I can only find information relating to it charging the leisure battery.
  • SeasideBill
    edited September 2021 #2
    That’s the most likely scenario, but if you locate the solar controller it should be obvious if it’s a dual charging unit.
  • SeasideBill
    edited September 2021 #3
    Another way of checking…with engine off on a sunny day, completely cover solar panel and test starter battery voltage. Next, remove cover and test voltage again. First reading should be about 13v and if second is about 14v the battery is receiving solar charge
