Water leaking below van when pump and taps on
ScreenName30009CE751
ScreenName30009CE751 Forum Participant Posts: 3 Participant
edited July 2021 in Motorhomes #1
Hi, we’ve bought a 2003 Ace Napoli motorhome and been away for the first time this weekend. When we turn the water pump on and run the taps, water is leaking out from under the van. After a quick Google we thought it might be the safety/drain valve was open, but having found that it was already closed. It’s a Truma.  I’ve looked and can’t see any other switches.  Has anyone any other ideas? Many thanks for any answers.
  • JohnM20
    edited July 2021 #2
    Check all pipe connections when the pump is running. Does the pump stop running when you close the taps?
    Cornersteady Club Member Posts: 15,414
    edited July 2021 #3
    This did happen to us once in our previous van but it was directly under the sink. It was a loose connector in the cold water pipe to tap. It came out under the caravan as it ran thought the gas drain holes. I suggest you get a team effort going and one person runs the water while other watch for where it comes out under the caravan and trace it back?
    Oh we also had a loose sink drain pipe. Easy to check - does it come out with the sink plug in.
    Hope you find it.
  • Kasspa
    Kasspa Club Member Posts: 379
    edited July 2021 #4
    Can you lift a seat & see where the pump & filter connections are or is it beyond that point?
    If it was the safety drain valve it would leak all the time I think simply thro' gravity.....
  • ScreenName30009CE751
    edited July 2021 #5
    Thanks all.  I'm going to run some Puriclean through the system tomorrow so I'll look at everything you've suggested and see if I have any luck
    edited July 2021 #6
  • chasncath
    chasncath Forum Participant Trusted Posts: 1,670
    edited July 2021 #7
    We've just replaced our drain down valve for just this problem. Examining the old valve revealed that an o-ring seal had gone. We had been getting bye by screwing the valve down with brute force!
    edited July 2021 #8
    Thanks everyone. We found that the water was running from a box under the van so contacted a motorhome and caravan repair specialist in the area who came with rave reviews. He had us send him tons of pics and take the fridge vents off. He has suggested that the mixer tap in the kitchen needs replacing as when we took the lower vent off, water was coming out of the pipes running behind the fridge. So we need a new tap which he’s going to fit for us.
    so currently sat on site at Southport in the scorching sun with a five litre water carry bag with tap for hand washing 😀
  • ScreenName6B23F9F1F1
    ScreenName6B23F9F1F1 Forum Participant Posts: 1 Participant
    edited July 2021 #9
    Could be worse,you could be sat at home.
    cool
    edited July 2021 #10
    At least its a pretty simple fix.
    PS taps are pretty easy to remove/ replace. I've just had to tighten up the horse shoe shaped clamp on my kitchen sink .... hardest bit is access. There's a clamp & each pipe is a push fit.
