Water into tank under bed
Rookie 1
Rookie 1 Forum Participant Posts: 16 Participant
I have a water tank under the caravan bed but the aqua roll is heavy to pour in via the funnel and hold at the same time
what could I use to maybe attach a pipe onto the Aqua roll and than just pour into the tank
    edited July 2021 #2
    How about a couple of watering cans instead of aqua roll?
  • Rookie 1
    edited July 2021 #3
    When I posted that I did actually think about a couple of cans of no other options I’ll do that
    thanks jvb66
  • Bakers2
    Bakers2 Forum Participant Trusted Posts: 8,679
    edited July 2021 #4
    Could be filled with a hose pipe and topped up with a watering can?
    Nit sure how you'd get on using a hose pipe of club site  unless yiu have a service pitch. Too heavy to tow filling it before 😱.
    I believe you can get a pump that would pump it in from the aquarol ??
  • Rookie 1
    edited July 2021 #5
    Bakers2 I was wondering if I could get a pump
  • richardandros
    richardandros Club Member Posts: 3,229
    edited July 2021 #6
    Without knowing exactly how your water system works, it's difficult to advise precisely as to the best way to overcome your problem - but in principle, there is no reason why your existing aquaroll pump shouldn't be able to fill the on-board tank via a diverter valve.  Our previous Bailey had this system - but it is essential that the on-board tank has an overflow pipe (through the floor) - so that you know when to switch the valve back without flooding the caravan!
    Our present Knaus has a different system in that all of our water comes from the inboard tank and therefore it has its own pump to supply water around the van. It's filled by the aquaroll pump which is controlled by a float switch in the inboard tank.  So that tank is always full as long as there is water in the aquaroll.  It would be quite an easy DIY job to install such a system in your van.
  • Burgundy
    100 Comments Name Dropper
    edited July 2021 #7
    for sale on ebay ;- search for - "Caravan toilet flush tank filler pump"
    just need somewhere to connect 12v supply, looks like cigarette lighter type plug
  • Graydjames
    Graydjames Forum Participant Posts: 471 Participant
    edited July 2021 #8
    I use a 12 volt submersible pump to fill my tank from an Aquaroll. However, this makes use of a 12 volt socket next to the filler cap on the side of my van. I gather you are a caravanner, but with an on board tank; so presumably no 12 volt socket?
    Maybe you could fit one - that is beyond my pay grade, but I am betting there are people who will tell you it is not difficult!
    My old van did not have a 12 volt socket so I used to use a 10 litre watering can to keep my tank topped up having firstly filled it at the motorhome service point. For you I think maybe the watering can is the better option (although I am a bit hazy as to why you would need two unless you are just trying to reduce the number of trips to a tap)!
    [Edit written before seeing last post above. Maybe that's your answer if you can plug into cigarette lighter (though you might need a long lead)]
  • Rookie 1
    edited July 2021 #9
    The caravan is a Cristal moorea from overseas
    it has a similar tank beneath the bed that is pumped to shower and sink
    an£ 8 think the water unit to heat is is called a trauma
  • Graydjames
    edited July 2021 #10
    Truma presumably though Trauma may not be wholly inappropriate!  wink smile
  • Lukeledge
    Lukeledge Club Member Posts: 84
    edited August 2021 #11
    I bought a cheap caravan submersible pump and wired it to a 12v cigarette lighter plug and a long enough bit of hose to reach from an Aquaroll to the filler hole of our motorhome water tank - just  plug in and transfer the water.
    Have only needed it when we have been at festivals and using  the shower in the MH - tank only lasts a couple of days then!
  • eribaMotters
    edited August 2021 #12
    I've had an onboard tank since 2007 on my Eriba caravans. I fill them using a watering can. Every time I empty my waste water bucket I add a fresh can of water to the tank. A watering can is a lot smaller, lighter and easier to carry than an aquaroll.
    Colin
    Tinwheeler Forum Participant Trusted Posts: 24,316
    edited August 2021 #13
    Have you not got an electrical connection to enable use of a submersible pump, Rookie? That’s the easiest method.
  • punto338
    punto338 Forum Participant Posts: 45 Participant
    edited August 2021 #14
    I have exactly the same system.  I use a large plastic funnel attached to a short piece of hose  and fill the tank up from a watering can.  Both the funnel and the watering can travel in the front gas locker.
  • punto338
    edited August 2021 #15
    I have exactly the same system. I use a large plastic funnel attached to a short piece of hose and fill the onboard tank up with a watering can.  Both the funnel and the watering can travel in the front gas locker.
