2011 Elddis Avante 564 battery charging problem
KSRobb
KSRobb Forum Participant Posts: 1 Participant
edited July 2021 in Caravans #1
I have a 2011 Elddis Avante 564 and the battery doesn't appear to be charging when connected to EHU. New battery, fully charged drains after few days even when connected to mains. Checked all fuses and doesn't appear to be a separate battery charger, at least not one I can see. Anyone any advice on battery charging in this model?
  • commeyras
    edited July 2021 #2
    It does sound as though the battery charger is shot.  I have a 2009 Bailey and this happened to me a few weeks ago when on holiday.  If your set up is similar to mine you have a box, mine is black, with various 12v fuses on the front.  The rear part of this is white and this is the charger - probably saying a 20 amp charger.  It is a simple diy job to replace.  Unplug mains, remove screws holding the unit to give access to the charger, lift it up to slide out, unplug the 2 electrical connections on the charger, slide in new charger and connect the 2 electrical connections.  Power up to see if the battery is charging.  If ok refit the unit.
    If you Google 'replacing battery charger on a caravan' there are a few videos.  If your set up is different to mine, go onto an Eldis forum and ask for help; but I understand charger set ups are fairly standard.  The charger should cost about £170.
  • commeyras
    edited July 2021 #3
    I have just followed my own advice and googled 'How to replace a caravan battery charger' and yes there is a video showing how to do it in 2 minutes!  It took me a little longer but was as simple as shown.  The charger part is aluminium coloured not white, sorry.
    edited July 2021 #4
     ... and yes there is a video showing how to do it in 2 minutes!
    are you going to post the link for KSRobb? 😉😉
  • commeyras
    edited July 2021 #5
    Will try to - bit of a troglodite!  Watch this space.
  • commeyras
    edited July 2021 #6
    https://youtu.be/Dx_hOIHGS2Q.  Hope this is ok!
  • commeyras
    edited July 2021 #7
    https://youtu.be/r_SY8zUpqiw, or this one.  How do I get it to say 'Link' or 'Here'?
    edited July 2021 #8
    >Link here<
    When you clicked the icon of a chain/link above, one of the boxes was marked  'Text to Display', this is the box that you put what you want to be displayed ie 'Link here'. Below it is another box that says 'open in new window' yes or no .... on every other forum I use, this will automatically open a new window, but as this forum is from the dark ages, it doesn't. But it would be far better if it did, so that you didn't lose the original page on CT
  • commeyras
    edited July 2021 #9
    KSRobb, where my links of any use?
