Whale water heater fault.
Zuco
Zuco Forum Participant Posts: 1 Participant
edited July 2021 in Caravans #1
Hi
I have a Venus 500/4. The Whale water heater is not working, the fault code is 3 flashing red lights.
The manual says with this fault there is a low/high supple voltage.
So I have turned all power off and on again
Then disconnected the battery and power cable, then reconnected. Still 3 flashing red lights and no hot water.
I don’t don’t know what else to try, any ideas please?
Thanks in advance.
Dan
  • Thewanderer
    Thewanderer Forum Participant Posts: 21 Participant
    edited July 2021 #2
    1.  has the 12volt fuse blown?
    2. have you got  12 volts at the heater?
    3. Is you caravan battery faulty?
    4. The Whale heater needs a 12 volt supply of between 10 volts and 15 volts.
    Best of luck.  I have a faulty Whale heater and cannot find anyone who can repair or advise.
    Whale just refer me to an authorised workshop who don't touch Whale gas heaters.
