Leisure battery use for kettle
ScreenName55EA96B6F9
ScreenName55EA96B6F9 Forum Participant Posts: 1 Participant
edited June 2021 in Motorhomes #1
Hi all
i have a Fiat bessacar motorhome snd am trying to find out how I boil a kettle on a road side stop. I’m assuming using the leisure battery somehow but documentation not very helpful.
can anyone help please ?
Vic
    Tinwheeler Forum Participant Trusted Posts: 24,397
    edited June 2021 #2
    No!!! Your leisure battery will only power 12v appliances, not your 240v kettle, hair dryer, microwave, iron etc etc. Nor will it power your fridge unless the engine is running. Boil a kettle on the gas ring.
    edited June 2021 #3
    it is possible to use 240V AC appliances via a 12v battery BUT you need an inverter which makes a kind of mains voltage. The easiest & cheapest way though is as TW suggests above .... keep it simple & use gas. 😉
    edited June 2021 #4
    there are a variety of things that will heat water using 12v click here but gas is still the easiest
    edited June 2021 #5
    I was trying to keep it as simple as possible for a newbie. I did think, though, that if I said not to try heating the plastic electric kettle on the gas ring, it might be seen as over doing the simplicity😂😂
  • nelliethehooker
    nelliethehooker Club Member Posts: 15,533
    edited June 2021 #6
    Wonder if OP ever did get his/her cuppa?
    edited June 2021 #7
     ... I was trying to keep it as simple as possible for a newbie
    Which is what I said 👍
    edited June 2021 #8
    Careful, ED, you might actually be agreeing with me🤣🤣🤣
    peedee Forum Participant Trusted Posts: 10,159
    edited June 2021 #9
    Even easier, fill a vacuum flask with boiling water before you set off. Use that to make a hot drink while on route.
    SteveL Club Member Posts: 12,556
    edited June 2021 #10
    Agree, it’s what we do. Perhaps a hold over from caravanning days when it was more of a faff, but works fo us.
    Those 12 volt electrical devices mentioned, take an age if you want more than one cup, we had one years ago.
    edited June 2021 #11
