External Locker/Garage door
JimL 2021
JimL 2021 Forum Participant Posts: 3 Participant
edited June 2021 in Motorhomes #1
Does anyone know who can actually fabricate a replacement door .I need to replace the door on my Eldiss Autoquest 600 but so far despite what I have been told ...no joy . Surely there are engineers somewhere  who fabricate to order. I just dont know any.
    edited June 2021 #2
    Most door apart from habitation, are locker doors frames with LV coloured infills made from the material, taken out of where the locker is to be fitted ,numerous frames are available on line ,check out Cak Tanks website
    Unless you have "lost the door"? You may be able to use some of the parts from the damaged ?one
    DavidKlyne Club Member Posts: 14,802
    edited June 2021 #3
    The Elddis Autoquest 600 were circa 2006 and it seems to be a door with no window which I imagine was used on many models. I think my first port of call would be the manufacturers to see if by any chance they have any spares or could point you in the direction of someone. Many seem to use motorhome breakers so an internet search might throw up a few options. Many motorhome manufacturers now seem to use specialist door makers like Dometic and Hartal.
    edited June 2021 #4
    I thought the op said garage door?  If it is the habitation door? just Google caravan habitation doors , as they are the same as most motor caravan doors, and it brings up many sizescool
    edited June 2021 #5
    I read the post rather than the title where the OP just mentions a door! However the same applies in terms of finding another.
  • JimL 2021
    edited June 2021 #6
    Thanks for the advice . I did contact Eldiss direct who dont hold stock of older models . Scrap yards same result but some good leads thank you all ..heres hoping!
    edited June 2021 #7
