Waste/fresh water emptying problem
tipmanal
tipmanal Forum Participant Posts: 2 Participant
edited June 2021 in Motorhomes #1
Hi
We have a Fiat Ducato Lunar Goldstar 620 and when we've been away and we're turning the taps to empty the water nothing comes out at ground level. When we get home, our drive where the vehicle is parked, is on a slope (front of vehicle at the top of the slope) and the water freely comes out then. Could anyone give ideas on how to solve this problem ?
Thankyou
  • Takethedogalong
    Takethedogalong Forum Participant Trusted Posts: 18,099
    edited June 2021 #2
    Perhaps you are slightly nose down on your pitch? If it comes out when you level it up on a slope then this seems logical.
    Re grey waste water, possibly sediment at bottom of tank?  We learned never to let big particles into our waste tank, we use a wash up bowl for rinsing and pot washing. In essence, the only thing that goes into our waste water tank is hand wash water and shower water. It keeps things fresher and flowing better. Quite surprising how easy the pipe work blocks occasionally, so better prevention than cure.
    Have a look underneath ad well for any kinks or drops in pipes.
    peedee Club Member Posts: 9,927
    edited June 2021 #3
     TDA is doing well if every bit of food/fat can be stopped going into the waste tank. I carry an old bit of TV coaxial cable in my locker which I can stuff up the waste outlet to clear any blockages. I suggest you put a dose of tank cleaner in the tank and go for a drive to shake it about before emptying. I do that a couple of times a year, keeps the smells away and the blockages at bay and there is always the bit of coax to hand if necessary
    Tinwheeler Forum Participant Trusted Posts: 24,151
    edited June 2021 #4
    We don’t put dish water into the tank at all, PD, so we're doing well too. It's easy enough to avoid. Have a bowl and carry it to a disposal point or hedge (with permission, naturally).
    edited June 2021 #5
    edited June 2021 #6
    May as well go to a dish washing area inthe first place if you are going to do that. I like an easier life than that, visit the MV waste disposal point when leavingand open the valve. I do the same if no disposal point but into a couple of collapsble buckets.
    edited June 2021 #7
    Not at all. Our water is hotter than site supplies and why carry a load of dishes around the site? Not all sites have dish wash areas and what's difficult about getting out of the van and taking a bowl of water to a drain or hedge?
    I could make the same negative observations regarding waste water disposal and carting buckets around. A hose piping it to a drain or hedge is much simpler.
    Each to their own, eh?
    SteveL Club Member Posts: 12,536
    edited June 2021 #8
    Tend to agree. We try and minimise it by wiping any excess oil fat / debris off pans / plates with kitchen paper. Not tremendously environmentally friendly but very effective. Any solid debris we miss are caught in some strainer things in the plug hole. If a pan is particularly messy I take it to the pot wash, as I do with the cadac.
    DavidKlyne Club Member Posts: 14,548
    edited June 2021 #9
    We try and pitch near a service point so washing up water can be disposed of easily. If that is not possible I pour it into our wheeled waste water container. With the current restrictions on Club sites it could be quite inconvenient to try and use site facilities.
    It would seem the OP has a partial blockage somewhere between the tank and the exit point. I suspect the OP will either have to disassemble the pipework from the tank or use Peedee's method. Probably a regular application of tank cleaner would help keep the system clean and blockage free in future?
