Reich Twin Water Pump help
Carolyn Cummings
Carolyn Cummings Forum Participant Posts: 2 Participant
edited May 2021 in Motorhomes #1
I recently bought a replacement water pump for the fresh water tank in my MH. The new Reich Twin 19l/min pump has come factory fitted with a non-return valve.  Can anyone tell me what I need and where I can source a fitting to attach the water pipe to the valve.  Please see photo attached.  Many thanks
    edited May 2021 #2
    does the pipe not simply slide over the end of the valve? Warm the plastic pipe to make it more flexible & push it over ... secure it with a Jubliee clip. Is there anything from the old pump that could be transferred to the new pump?
    edited May 2021 #3
    To add to the above post ,ensure the jubilee clip is slid onto the pipe before attaching pope to pumpwink
  • Carolyn Cummings
    edited May 2021 #4
    Many thanks for the replies.  The pipe will fit directly to the valve after warming but there's very little holding it in place.  As I have to drop the water tank to access the pump I need to know that there's a secure fix before I re-install. I only want to do this once!  The screw thread on the valve suggests a fitting is available specifically for this task.
  • timetoroam
    timetoroam Forum Participant Posts: 1 Participant
    edited May 2021 #5
    The origional pump had the screwed connector. When the pump was changed and the connecting pipe I could not use the screwed connector So i installed it with a tight fitting pipe and  jubilee clip works fine.
