Battery charging
T rev
T rev Forum Participant Posts: 27 Participant
Being new to motorhomes - a quick question.
When hooked up to mains electrics are both the leisure battery and the vehicle battery being charged?
Also when the engine is running is it charging both batteries?
Thanks
T
    Tinwheeler Forum Participant Trusted Posts: 24,153
    edited May 2021 #2
    Without knowing the details of your control unit, it's impossible to be sure. Your handbook should tell you.
    The answer to both your questions is normally yes but I can’t be certain in your case. You may need to switch charge from one to the other.
    PS. If you visit My Profile at the head of the page, you'll be able to give yourself a user name of your choice.
  • T rev
    edited May 2021 #3
    Will check in handbook.
    thanks for help
    edited May 2021 #4
    Any relation to T rex?
