Cassette toilet door
plainbob
plainbob Club Member Posts: 10
edited April 2021 in Parts & Accessories #1
The push-button catch on my external toilet door compartment recently stopped functioning,   On undoing the backplate everything fell out.   There does not appear to be anything broken or missing;   I think that one of the springs had moved from its proper location.   I have looked on the "net" but cannot find a decent diagram to show me how to put it back together.   The Thetford website is of no use.   Does anyone have a diagram which would be of help.
  • Metheven
    1,500 Likes 1000 Comments
    edited April 2021 #2
    Is there anything of use in this PDF file?
    https://www.leisurespares.co.uk/files/ww/EXTERIOR%20PRODUCTS.pdf
  • plainbob
    edited April 2021 #3
    Thank you for your quick reply.   It is helpful although I am still trying to work out from the diagram how the parts fit together.    It has also helped with identifying a missing clip from the fridge vent.
  • mnlatham
    mnlatham Club Member Posts: 108
    edited April 2021 #4
    Could you remove a different backplate from another locker door carefully and see the set up first hand?
  • commeyras
    edited April 2021 #5
    If all else fails replacement locks are easily available and not very expensive.  Google, as always, is your friend.
  • plainbob
    edited April 2021 #6
    Am reluctant to open the back plate on another door as the contents ejected very quickly before I got a chance to observe how they fitted together.   I have looked on Google and so far have only seen a picture of the locking catch rather than the push-button one and I am unable to get a clear idea of how the parts fit together.   There are three springs involved and it looks like a job for a spare pair of hands!
  • commeyras
    edited April 2021 #7
    Try contacting the following, they may be able to help:
    Leisure Spares  01423 320009
    Caravan Parts 01926 64089
    Leisuresparesdirect via their web page
    I think it is a Door 3 lock you are talking about.
    Good luck.
  • plainbob
    edited April 2021 #8
    Thank you for your various pieces of advice.   It looks as though my best course of action will be to take the door off its hinges and lay it flat whilst trying to reassemble the catch.   Our van is kept on a storage site some miles away so it is not so easy as having it at home where tools (if needed) would be readily available.   The contacts give above may well prove useful.   Thank you
