Water problems
ScreenName9B00CC5759
ScreenName9B00CC5759 Forum Participant Posts: 1 Participant
edited November 2020 in Caravans #1
Hi there I’m new to caravaning so bear with me .
im having problems with my water system,, I prime my system as normal and everything works ok,, but overnight something is happening and when I turn on my tap I’m getting air coming out again and the water is cold !!!
then eventually the air stops but the water remains cold ,,
can anyone help
Moved from the Story Section
    edited November 2020 #2
    Did you purge "all" the air out when setting up? You need to do it for both hot and cold settings. If you've been trying to heat water with an empty or partially full boiler, it may have tripped out and need resetting.
    KjellNN Club Member Posts: 8,973
    edited November 2020 #3
    Which van do you have, and what type of heating system?
  • paulfrompontefract
    paulfrompontefract Forum Participant Posts: 31 Participant
    edited November 2020 #4
    We had a similar issue last time out, we were advised to re set the water pressure switch on the cold water inlet, if you look in your handbook it’ll explain how to do this,  reasonably straightforward and it resolved our problems
  • KeithL
    KeithL Forum Participant Posts: 114 Participant
    edited November 2020 #5
    Make sure your feed in the aqua roll is not floating up to the water surface. Had this problem a few times until I clicked.
    To check it out I filled a plastic bag with stones and tied it to the water filter, I have an onboard pump, which ensured inlet stayed at the bottom of the aqua roll and fault cleared.
    I now have one of these and haven't had any problems since:
    https://www.ebay.co.uk/itm/154161497568
