Outdoor Revolution - Electric Pump Help
trussers
trussers Club Member Posts: 16
edited August 2020 in Parts & Accessories #1
Hi all.  I have just taken delivery of a new OR Eclipse.  It looks great in the bag (not put up yet), but I may have goofed, as it is heavier than I thought (probably just as heavy as the Kampa 390 Pro it is intended to replace), and the bit on my Gale pump that I thought would fit the OR I am beginning to think might not.  Does anyone use a Gale pump with an Outdoor Revolution awning?  If not, does anyone know what electric pump does the job?  I have looked for one of the OR Jetstream pumps, but they appear out of stock and no longer being produced.  Any advice gratefully received.
I am an old geezer with a dodgy back, so this weight plus the 26 pumps on the hand pump will finish me off.  So, possibly an Ebay moment I shall regret!
  • SeasideBill
    edited August 2020 #2
    I know absolutely nothing about inflatable awnings, but had plenty of experience of inflatable marine stuff and the Sevylor 12v Pump is a good bit of kit. Inflate to 15psi with adjustable shut down once desired pressure has been reached. Plenty of adapters so I’m sure one would be compatible with your awning? About £50
  • trussers
    edited September 2020 #3
    Thanks to Seaside Bill for reply.  As it happens, I have now had the awning up, used the Kampa pump, which works fine, and the awning is excellent.  It is heavy for the size, but everything else bodes well.
