Battery box barrel lock
olduns14
olduns14 Forum Participant Posts: 13 Participant
My battery box lock on my Bailey Pursuit Plus 430/4 has been vandalised and battery stolen. Struggling to remove lock and not sure what lock removal key I need, and whether it will work given the damage. Considering other option of buying new door but Bailey cant supply a lock until September. Anybody had similar experience and and is it a straightforward job to put in  a new lock, maybe a generic lock available on ebay. Any guidance would be appreciated. Thanks
    edited July 2020 #2
    Most locks on LV lockers are the same, most dealers will have them in stock   or look at CAK TANKS website they will have them
  • olduns14
    edited July 2020 #3
    Thanks I will have a look. Any thoughts on removing the vandalised lock and inserting new one.
  • commeyras
    edited July 2020 #4
    Sorry to hear about your problem.  Think the battery door lock is different from others , had a quick look and they are on my Bailey Ranger,  so make sure you get the right one!  If you can remove the lock a quick Google search will show that you can get a replacement lock for just over £12. If you need a new door complete they are about £50 and you will probably get away with replacing just the facia part (where the lock is).  Not sure there is a lock removal key.  Try using a metal bit on your drill in the centre of the lock it may get it off, nothing to lose if not!  Have a chat with your local dealer or Service Engineer.
  • commeyras
    edited July 2020 #5
    Re my above.  Sorry, have just seen a video and there is a lock removal tool!  He shows using the tool or an old steak knife.  Just Google ' 'How to remove vandalised lock on caravan battery box door' and you will see it.  Replacing the door is a simple but more expensive solution. I had to change the door (No 5 I think it is called) to the external storage a few years ago.  No problems and I was able to reuse the old locks thus saving having yet another key.  Hope this helps.
  • olduns14
    edited July 2020 #6
    Thanks for the advice everyone I will have a go at the options and let you know how I get on.
