Help with Motorhome laid up for long term
Lvlv
Lvlv Forum Participant Posts: 7 Participant
edited April 2020 in Motorhomes #1
We have a new (2019) Elddis Accordo 120 Majestic motorhome. It has a solar panel. I am concerned that it wont start after a long time on the drive.
The Elddis and Peugot Handbooks are next to useless for a novice. I don’t know if the vehicle battery is charged when hooked up or if the solar panel charges the vehicle battery.
My wife is on the extremely vulnerable list so I have to self isolate too, which means I can’t give the motorhome a run to the shops.
Can anyone advise.
Take care and stay safe.cool
«1
    edited April 2020 #2
    Have you got  a car Battery charger? it should do the job if you can get to the battery?  i think it is under the carpet in the passenger side foot well?
    edited April 2020 #3
    edited April 2020 #4
  • Lvlv
    edited April 2020 #5
    Thanks for your replies. I don’t think  I've explained myself correctly.
    I’d like to know if  I plug the hook up into the mains will it charge the vehicle battery as well as the habitation battery?
    and
    How do I know if the solar panel is charging the vehicle battery as well as the habitation battery?
    Cheers👍
  • Lvlv
    edited April 2020 #6
    Thanks BoleroBoy. I’ll try your suggestions if I don’t get any replies from members with the same outfit.👍
    DavidKlyne Club Member Posts: 14,726
    edited April 2020 #7
    I can't speak for Elddis but both my Bailey motorhomes on a Peugeot base did not charge the cab battery from the internal electrics, only whilst the engine is running. As far as the solar panel is concerned you need to check the controller to see how many wires run from the distribution terminals. If there are only two it would suggest its only charging the leisure battery. However if there are four there is a good chance it is also charging the cab battery. There is usually a setting on the controller which decides which proportion of charge goes to what battery. Unfortunately with my Bailey the manufacturers were two mean to connect the solar panel to the cab batter. I got over that by having a device called a Battery Master fitted which pushes excess charge from the leisure battery to the cab battery to keep it in good condition. The advantage of the device it works also on mains. Also had one on my previous Bailey motorhome for nearly six years and never had a cab battery problem.
    Just a thought, if you are on Facebook it might be worth looking to see if there is an Elddis owners group.
  • Lvlv
    edited April 2020 #8
    Thanks David your information/suggestions are very useful.
    Cheers👍
    edited April 2020 #9
    I've got a 2016 Marquis Majestic 125 - Accordo lookalike. The Charger unit doesn't charge the engine but I have run a supply from the Solar to the engine battery otherwise the alarms deplete the battery over a period.
  • Vanfan
    Vanfan Forum Participant Posts: 8 Participant
    edited April 2020 #10
    I have a Majestic 120 and neither the charger nor the solar panel charge the engine battery. As it will go fairly flat inside a Month due to the alarm mainly, you will need to charge the engine battery yourself.
    The best way would be to do as suggested above and connect the solar panel, but if you don't have the expertise to do this properly then you'll need to connect a charger.
    The battery is under the large lid in the passenger footwell, and if you have a permanant hookup the simplest way is to connect an intelligent charger like a CTEK.
  • JollyKernow
    edited April 2020 #11
    Evening
    A cheap way to maintain both batteries is, if you can, run a cable (1.5mm should suffice) between both batteries. Connect this to each positive terminal. Ideally install an inline fuse in that cable (10amp) close to the vehicle battery. Your ehu and/ or solar will then charge both batteries. I tried this on my last van and it worked well so I wired it permanently, then just removed the fuse when needed. Hope this is of some help?
    JK
  • KeithandMargaret
    edited April 2020 #12
    I've had a CBE CSB2 trickle charger fitted for around six years to keep the Starter battery charged up and it works very well.
    For around £20 and easy wiring they are well worth the investment.
    I have only been on hook up a few times over the years at home or away and have never had a problem with the two 110 Ah leisure batteries or the starter battery which are maintenance free.
    I have an 80W Solar panel helping to keep the leisure batteries charged and with the help of the CSB2 the starter battery is always topped up.
    Although there are more expensive devices than this one I've never had any need to worry about my batteries.
    Two Digital Voltmeter Panels, for less than a fiver for the pair, will show you the charge of your Leisure and Starter batteries.
  • Phishing
    250 Likes 500 Comments
    edited April 2020 #13
    If its on the drive then start it, blip the throttle to 2000 rpm and then hold it it at about 1200 for 5 min once a week and it will keep the battery topped up. If it was in good SOC when you parked it up it should survive for months, new vehicles have extremely low quiescent current.
    edited April 2020 #14
    Others on the keeping a tow vehicles battery healthy thread, would not agree.🤔
    edited April 2020 #15
    Keeping it topped up with the solar panel is less hassle and more environmentally friendly and probably better for your engine.
    edited April 2020 #16
    Lvlv, the simplest way by far is to isolate the battery by means of the red button by your ignition switch. Your Peugeot handbook will explain all.
  • Heethers
    edited April 2020 #17
    My Auto trail has two battery icons, one for leisure and one for vehicle battery, when on hook up at home l select which battery to charge and alternate every 5 days or more. l assume the solar panel was fitted by the Elddis which in my experience would mean only the Leisure battery would be charged, as said on an earlier post you can check by putting a multimeter across the terminals on both batteries to see if you are getting the right volts, usually around 13.8 to 14 volts
    edited April 2020 #18
    edited April 2020 #19
    Obviously it won't help if the battery is already flat, BB.😄
    The OP has made no mention of an alarm or tracker being fed by the vehicle battery.
    edited April 2020 #20
    but by the OP's own admission he/she is a novice so does he/she even know if there's an alarm or tracker fitted? 😏
    edited April 2020 #21
    I don't know and we don't know what the OP doesn't know 🙂
    edited April 2020 #22
    edited April 2020 #23
    @ BB .... has a relay (electronic 'non return valve')
    Would your 'none return valve' not be a diode? A relay is a switch ...
    but I agree with everything else re similar batteries etc 😊
    edited April 2020 #24
  • ATDel
    ATDel Club Member Posts: 335
    edited April 2020 #25
    Being a Majestic the solar may very well be linked to the van battery as well as your habitation battery. You can check by looking at your controller. It should be a truma controller sd10 and if the cab battery is attached you will have 3 sets of wires going into it. If you only have 2 sets of wires into it then it will not be connected. We have a dealer special Autoquest and I connected the cab battery to to controller myself.
  • ATDel
    edited April 2020 #26
    Sorry forgot to say it’s very doubtful that ehh will charge the cab batter either. I understand that the encore range had that until 2019 and no longer has that facility, the encore being the top of the range in Elddis motorhome production
    edited April 2020 #27
    I knew what you meant .... 😉
    peedee Club Member Posts: 10,072
    edited April 2020 #28
    "Which" has published an article about maintaining little used vehicles during lockdown. Click >here<
  • Dave Nicholson
    Dave Nicholson Forum Participant Posts: 408 Participant
    edited April 2020 #29
    The advice above that reads  “A cheap way to maintain both batteries“ by connecting them together with a 1.5mmsq cable is foolhardy and should not be considered whether an inline fuse is fitted or not!  The current delivered under short circuit conditions from a vehicle or leisure battery under fault conditions is so high that it would not only melt the small cable but could also start a fire. If batteries are being paralleled then the cable connecting them should be no smaller than that fitted by the vehicle manufacturers. If a fuse is fitted AT THE VEHICLE BATTERY TERMINAL the size of the cable to the second battery could be reduced but the required cable size would need to be calculated by a competent electrical engineer. A second fuse would also be needed at the leisure battery terminal to protect the cable from a short circuit from that battery too.  Please don’t attempt to connect batteries ‘on the cheap’. Split charge relays are available or, as others have said, there are proprietary devices available to do this safely.
  • Amesford
    edited April 2020 #30
    I find these useful I keep one in the car the other in the caravan, you can buy them for as little as a couple of quid
    edited April 2020 #31
    Looks an interesting little gadget, could save going under the bonnet with the multimeter!
