Battery Charging
JohnM20
edited March 2020 in Towcars & Towing #1
With my car being used far less at present I'm concerned that my battery will end up flat. At most the car is used for a four mile round trip to the shops no more than once per week and needs starting at least twice to do the trip. The short distance will not be enough to replace what the starter motor has used. It is many years since I've needed to charge a car battery so my question is do I have to disconnect the battery to charge it? Years ago it was recommended but I'm not sure with modern cars (2015 Mondeo) as so many background devices in the car need a constant power supply. Any advice anyone?
    peedee Forum Participant Trusted Posts: 10,124
    edited March 2020 #2
    Take a longer route to the shops now and again. I have a much shorter journey in our run around and with a good battery I have never had a need to charge it in 5 years of ownership.
    I would disconnect the battery according to instructions which I think is remove the positive first if your vehicle is negatively earthed.
  • JohnM20
    edited March 2020 #3
    I should have added, there is nothing in the car handbook about battery charging.
    edited March 2020 #4
    I've never disconnected a battery to charge it except when one was completely flattened and I  mean flattened. Trying to charge it then made the electrics do all sorts or weird stuff. Just keeping a battery topped up I would just do it in situ.
  • marchie1053
    marchie1053 Forum Participant Posts: 584 Participant
    edited March 2020 #5
    The vehicle handbook will probably tell you to ensure that the Battery Charger earth terminal  is connected to the car bodywork [probably has a dedicated connection point] rather than to the car battery negative terminal. Modern electrical systems can be damaged if you don't observe this rule, apparently.
    Steve
    edited March 2020 #6
    It was 50 50 & you got it WRONG. When disconnecting a battery you disconnect the NEGATIVE  first. Reason being is that if you then short the NEGATIVE terminal to the body nothing will happen ie it's the same potential. If you disconnected the positive first & shorted the spanner across the body then you'd have shorted the battery too.
    You can leave the battery connected when connecting the battery charger  ..... Ctek provide the connector plug/socket to do it. My Smart spent months connected to a Ctek until last week with no problems. My motor bike has spent the last couple years likewise.
  • Metheven
    1,500 Likes 1000 Comments
    edited March 2020 #7
    If you have a 'Smart Charger' such as a CTEK for example then there is no need to disconnect the battery, plus if it is your towcar then you can do as I have done. My spare CTEK lead has a 13 pin towing socket attached and I do it via the back of the car.
  • Whittakerr
    Whittakerr Club Member Posts: 3,486
    edited March 2020 #8
    For a minute then i thought you were charging the battery of your tow car by plugging the charger in to the 13 pin towing socket!surprised
  • Metheven
    edited March 2020 #9
    On re-reading my post I think I should have written 'towing plug' and not socket frown Anyways, here is my way of topping up the towcar battery occasionally. smile
    edited March 2020 #10
    With the summer coming, a 20watt solar panel on the dashboard and connected to your battery should keep it trickle charged. Not very effective if the car is in your garage though but most people leave their £30K car on the drive and fill the garage with £32.50's worth of dross.
  • Amesford
    edited March 2020 #11
     Over the winter going on short trips using the Heater and rear window demister and mirror heaters the poor battery has no chance so I connect the battery charger to battery insitu just to keep it fully charged
    edited March 2020 #12
    Thanks M after I thought about it a  bit more realised I got it wrong.
    edited March 2020 #13
     quite true but the trouble is that garages built 40+ years ago wouldn't be able to take a modern car, just like the spacing in most car parks.
    edited March 2020 #14
    I apologise for the fact my post came across as it did. I was on my phone at the time & perhaps should've used a few smilies 🙂
    edited March 2020 #15
    I garage my Smart Roadster 😉 Not a chance with the ML 😂
