Ace Siena control panel/solar panel/leisure batter
Tdub49
Tdub49 Forum Participant Posts: 2 Participant
edited January 2020 in Motorhomes #1
Hi, I'm new to the world of MoHos and have an Ace Siena.  It developed a fault whereby the control panel would not turn on and the steps would not deploy.  Back to the supplier under waranty and they "fixed" the problem by resetting the control panel.  They weren't terribly forthcoming about why it would need that but hey-ho.
Now and week or so later and the control panel is a little flaky in that it won't always turn on but when it does, the leisure battery shows about 10 volts and the LEDs on the charger relay show the solar panel 'knows' that there is an engine battery but is dead as far as the leisure battery is concerned.  Start the engine and life returns to normal, both batteries charging and will charge all day on the solar panel.  Overnight the leisure battery dies and we go through the same routine again.
I am assuming that this means the leisure battery is effectively dead but before I replace it, does anyone know if there is another possible cause for these symptoms?
Thanks.
    edited January 2020 #2
    Check the voltage on the leisure battery about 30/60 minutes after sunset. That will establish whether there is any decent voltage in it. If that is OK then it would suggest that the battery is discharging through an open circuit somewhere. If you have only just bought the MH, take it back and get the dealer to sort it out properly.
    edited January 2020 #3
