LED Lights
Tigi
Forum Participant Posts: 1,037 Participant
Currently running a 2018 Volvo XC60 and I will be changing van from a Lunar Clubman to a Swift Elegance next month, so this will be our first caravan with LED Road Lights. Can those of you with experience of a recent Volvo confirm whether the car is compatible with the Swift road lighting or if a Sargant Box is required. I`ll be trying the car on one of the dealers vans soon as a test but as they say forearmed is forewarned. Many thanks.
Best way is to go to a dealers and ask could you connect car to a caravan and check if all lighting works, that's what I did and found all worked well on the Jeep. You know then for sure if any problems that need attention.
