Spinflo Midi Prima OP60000 grill problem
dajome
dajome Forum Participant Posts: 1 Participant
edited October 2019 in Parts & Accessories #1
I have a Bailey Pageant Vendee 2004 with a Spinflo Midi Prima PO60000 full height oven/ grill but the grill won’t stay alight. I’m assuming it’s the thermocouple as the gas will light ok when I have the gas knob turned on and pushed in, it just won’t stay on when I let go of the knob.
Has anyone had similar problems with this model grill?
Can anyone give me advice and guidance regarding replacing the thermocouple - can I do it with the unit in-situ or do I need to remove the oven/ grill unit first?
Many thanks in advance for any advice.
  • JohnM20
    edited October 2019 #2
    You may find that the whole of the cooker needs to be removed to get at some of the connections. I hope I'm wrong.  I had to have this done when the thermocouple failed on the top burner of my Spinflo made Thetford cooker.
  • Amesford
    edited October 2019 #3
    The rings and grill on the cookers on some of caravans were the same and we had the thermocouples changed but when it happened  on our latest van I pointed this out to our mobile service engineer he just pulled off the knob packed some card in the hole replaced and it worked that was 2 years ago and it still works so I would try that first
