Elddis 185 Fresh Water Meter faulty
Dale McKean
Dale McKean Forum Participant Posts: 1 Participant
edited September 2019 in Motorhomes #1
Hi
I bought a Elddis 185 in Jun 18 it has been back to the Elddis agent under warranty 5 times and they cannot calibrate the Fresh Water Tank Meter, its still a problem even though they have changed all the components anyone else had this problem / had it resolved and how ?
Thanks
    edited September 2019 #2
    edited September 2019 #3
    Tank gauges are notoriously inaccurate. Ours isn’t too bad unless we’ve driven over rough roads or been on a bumpy ferry trip. It settles eventually.
    DavidKlyne Club Member Posts: 14,606
    edited September 2019 #4
    I would sometimes had to recalibrate the water gauge on my previous Bailey motorhome. It was a fairly easy thing to do once you have the instructions and must be done with the tank empty. If there is a Facebook group  for your make of motorhome someone on there may have the instructions.
    edited September 2019 #5
    I've recalibrated the water meter on my Marquis(Elddis)125. Waste of time. It still only gives a rough approximation. Happiness is a full water tank.
  • dougA
    dougA Forum Participant Posts: 142 Participant
    edited September 2019 #6
    Hi.........fresh water meter 😤. I have a Elddis 196 and I’ve had the meter recalibrated several times and a new unit fitted. It’s currently at my dealers at present for other warranty repairs and this is always on my list of repairs. They recalibrate say it’s working then I fill up full and it only shows just over have full on the meter.
    What I have noticed is that I have been at Great Yarmouth twice over the last three years and after filling up down there no matter how much water is in the tank the reading jumps straight to full and stays there.
    I read on a forum that the hard water down south can cause erratic readings.
  • antirampman
    antirampman Forum Participant Posts: 21 Participant
    edited September 2019 #7
    I have had several Elddis vans over the years, some years ago they had a small adjuster knob at the side which enabled you to adjust the level each time you filled up but since they stopped fitting the knob the meters have been pretty near useless. the hardness of the water used does affect the reading as well. The last Elddis I had showed full until it had about 10 litres left I used to fill up as soon as it showed any movement.
    edited September 2019 #8
  • ABM
    edited September 2019 #9
    Long since given up using the Fresh water Meter. I just do a top-up / refill every other day and, as CY says, that keeps ME happy !!
  • BlueVanMan
    100 Comments Name Dropper
    edited September 2019 #10
    I'm with ABM.
    In my early days as a motor-homer I used to take out the sensor (three metal rods of different lengths so actually a pretty simple, dare I say crude device)  on my Hymer Van 522 and clean them to keep the fresh water level gauge working. Nowadays on different van  I don't rely on it. It's just too much trouble.
    As a generalisation and in my relatively limited experience fresh gauges work reasonably well most of the time but grey water gauges are less reliable. Accuracy can be compromised in some vans for example if the van is not level.
    With experience you will get to know how much water you are using and when to fill up (and empty). Also how much water you use and carry will depend on circumstances. For example if you are travelling 400 miles to site there is no point in carrying a lot of water.
    We mostly use a 12.5 litre water carrier and a funnel so you can fill up from any tap, sometimes a short hose cut off from a longer one.  OK it may take a few trips but carrying the weight and walking is also good exercise !!
    Your tank is full when water runs out of the filler (but make sure if you have an inboard tank with a top cap that this is on and tightly closed.
    edited September 2019 #11
