Replacement work top
EmilysDad
edited August 2019 in Parts & Accessories #1
Has anyone ever had a worktop satisfactorily replaced? SWMBO decided to break up a bag of ice in the middle of a worktop last night & surprise surprise she's dented  the blasted thing ...... but it apparently wasn't her fault!! 😡😡😡😡
(2013 Coachman)
«1
    edited August 2019 #2
    I had a kitchen worktop replaced on a Swift 15 years ago. No idea of cost but it was a totally successful replacement. We bought an ex display caravan where some of the edging was loose. A couple of self tappers was the temporary repair by the dealer whilst he awaited the replacement top
    edited August 2019 #3
    Thanks Allan. I'll enquire when I get home  ... in the mean time I'll have a bl**dy big dent to look at. 😐
  • mickysf
    edited August 2019 #4
    Repairable? Several products and solutions have been previously suggested in other similar threads.
    edited August 2019 #5
    Thanks. It'll give me something else to sort when I get back home on top of putting her car back together & MOTing it 😣
    edited August 2019 #6
    If you can get the worktop out you could purchase a new from DIY suppliers and use damaged one as a template. I bet a bench joiner could cut it for you at a reasonable price. Then the vandal could have her choice of design.
    edited August 2019 #7
    Possible I suppose but .... the damaged bit is butted up to another piece that extends behind the oven adjacent to it. And besides its hollow to save weight .... which allowed itvto be dented in the first place. 😔 and its only about 3/4" thick
    To say I'm not pleased ..... sealed
    edited August 2019 #8
    Skin it with formica?
    edited August 2019 #9
    Have you got a "mens shed" in your area, ask themcool
  • Freedom a whitebox
    edited August 2019 #10
    Being a 2013 model, I would guess that a replacement worktop would available from coachman. Might be a tad pricey, but would be a perfect fit and leave the van in original condition
    edited August 2019 #11
     ...... to be continued!
  • mickysf
    edited August 2019 #12
    Cut out with multi tool and 'sink' in a cutting board. Could use coloured sealant to fix and neaten the edges. Just a longer term temporary repair mind which will hide a little of the evidence somewhat and give time to think of a permanent solution.embarassed
    edited August 2019 #13
    Tell OH " you broke ..... you fix it" cool
    edited August 2019 #14
    Funnily enough our previous caravan had two glazed tiles set into a worktop which we think must have been a similar repair to a dented worktop.
    edited August 2019 #15
    I might be brave .... but not stupid 😉
    edited August 2019 #16
    That could be then  a case where "use it or lose it" could be implemented surprisedwink
  • Takethedogalong
    Takethedogalong Forum Participant Trusted Posts: 18,486
    edited August 2019 #17
    Old trick used to be to turn them over, but nowadays probably not practical.
    edited August 2019 #18
    Unfortunately this is a shaped piece that has the kitchen sink in it.
  • ocsid
    edited August 2019 #19
    The course I would take on a 6 year old van would be influenced by who picks up the tabs, as I can't see it being anything but very expensive.
    If it was not my insurer then like has been suggested earlier I would be doing some lateral thinking of what sort of inset, or wider area resurfacing feature would look the less bodge like.
    At home we once had a stainless steel top protector, a quite big sheet with a "satin" finish. That lived as a permanent feature though it covered no "nasty", but did not look out of place either so did not get stowed away when not actually in use. Something of that ilk might be an option?
    edited August 2019 #20
    I suspect yours truely will be paying .... sealed
    edited August 2019 #21
     Formica, not heard that name for a few years. wink
    edited August 2019 #22
    Do a Blue Peter job, fill it in and cover with sticky backed plastic. surprised Sorted.
    edited August 2019 #23
     .... and here's one I prepared earlier cool
    edited August 2019 #24
    I could make a caravan shaped piece of stainless at work! 😂
  • jennyc
    edited August 2019 #25
    I’m wondering how the damage looks from above. If the laminate is still there, albeit cracked, you might consider squirting some expanding polyurethane foam in through a hole drilled underneath. It’s expansion is powerful so you could consider laying a sheet of glass on top, weighted down by a concrete breeze block, suitably padded from the glass. Once it’s set and the glass removed, you should be able to fill imperfections with a polyester resin filler, which will also take a limited amount of cellulose paint from a car touch up kit. As an alternative to polyester filler, two part epoxy putty is sold in a variety of colours for filling chips and joins in granite worktops. It’s a job which requires patience and care, but done sympathetically, you can achieve a very high standard of restoration,
    edited August 2019 #26
    Not a bad idea jennyc but the original surface isn't a shiney smooth surface like Cyberyatch's suggested Formica ... it has a very slightly textured finish.
    edited August 2019 #27
    New caravan MM. surprised
  • brue
    edited August 2019 #28
    Apart from a friend who dropped a tin onto their caravan work surface which got covered up with a glass chopping sheet you could try looking at You Tube. I did a miracle cure on a dented wood table thanks to YouTube, I bet there's a work top cure on there somewhere! smile
    edited August 2019 #29
    Lol .... a tad excessive Lornalou 😅
    edited August 2019 #30
    I'll look into it when I'm back home 😉😉
    KjellNN Club Member Posts: 9,091
    edited September 2019 #31
