Caravan battery charge
Mollieperkins
Mollieperkins Club Member Posts: 15
Hi
Does anyone who has a van in storage bring the battery home and use a trickle charger to keep it topped up?
If so which is the best one to use please?
  • commeyras
    edited August 2019 #2
    Yes, I do.  I use a middle of the range charger from Halfords.  Don't leave it attached all the time just top it up when needed.
  • Merve
    edited August 2019 #3
    Have you thought of a Solar panel? No more running backwards and forwards with batteries? The day I fitted one it kept my lead Acid charged at all times and kept the alarm and tracker alive.
  • Phishing
    250 Likes 500 Comments
    edited August 2019 #4
    Best charger is C-Tek, but a small solar panel in the front window will do the job with a decent controller for less money and less hassle.
    edited August 2019 #5
    Assuming you don’t have an alarm then, yes, keep it at home and give it a top-up charge once per month. Many trickle chargers are not suitable for permanent connection.
    I had a spare battery and swapped it from time to time in order to keep the alarm active.
  • Mollieperkins
    edited August 2019 #6
    Thank you for your replies.
    We like the idea of a solar panel, how does this connect to a battery please?
    We also don’t have an alarm at the moment as just bought the van, but think we should get one?
    thank you
  • Wellys and Mac
    Wellys and Mac Forum Participant Posts: 447 Participant
    edited August 2019 #7
    When my previous caravan was in storage I never brought the battery home.
    Motor mover never failed once.
