Ford S-Max auto-box
Lewisontour
Lewisontour Forum Participant Posts: 19 Participant
edited June 2019 in Towcars & Towing #1
Hi.  We currently have a Ford S-Max 2.0 litre diesel manual box car (12 plate).  I would like to change it for another S-Max (the greatest family cars ever? smile) only this time I am thinking of going for an auto-box - I think Ford call it Powershift.
I've never owned an auto-box vehicle before, so:
1) what is the auto-box like for towing?
2) how bullet proof/robust is the Ford auto-box?
Thoughts/experiences please.
Thanks
    edited June 2019 #2
    Towing with a 'proper' torque converter auto is THE way to go. Ford's Powershift auto is not without its problems .... it's a manual gearbox with auto controls (and is often called something else quite similar innocent)
    https://www.youtube.com/watch?v=4OSDw-uyP98&t=258s
    Take note at 8min 40secs wink
    Tinwheeler Forum Participant Trusted Posts: 24,295
    edited June 2019 #3
    You need to establish what sort of auto box it is as opposed to Ford's fancy name. If it’s a torque converter it will be very bulletproof and perform well when towing. Others such as dual clutch boxes, automated manuals or continually variable transmission systems may or may not perform as well. If it’s a dual clutch box, ensure it is the wet type rather than the dry which is more prone to problems. Unfortunately, most car salesmen won’t know the difference.
    Word on the grapevine is that the Ford auto box is not good.
  • Lewisontour
    edited June 2019 #4
    MollysMummy - wow!  He doesn't pull any punches on the Ford Powershi* (9mins 25s) surprised
    edited June 2019 #5
    He doesn't seem to be a fan does he? 🤣🤣
  • flatcoat
    edited June 2019 #6
    The latest Powershift are TC boxes. Not quite sure when introduced (2016 i think). Somehow Ford just didn't get their version of DSG sorted and finally ditched them (i think across the board). As stated above generally wet plate DSG are fine IF they are properly serviced, but then again TC boxes need a fluid change even if allegedly sealed for life.
    edited June 2019 #7
    Pretty sure like wise Vauxhall & their Easytronic automated manual
  • V70Ranger
    V70Ranger Club Member Posts: 46
    Name Dropper First Comment
    edited June 2019 #8
    I tow with a Ford Edge which has the 6 speed auto. Having retired and using the van (Unicorn Cartagena about 1650kg) almost all the time due having a house built we have been touring for about 15 months!
    No issues with the gear box and never need to put it in sport for manual control. I may be wrong but I think the diesel cars have the wet clutch?
    Mine is a 2017 model.
    Cheers
    V70Ranger
  • flatcoat
    edited June 2019 #9
    I think the Edge is a TC box. The just launched Ford Puma (SUV) had a 7 speed DSG type box option.
  • MDD10
    edited July 2019 #10
    Lewisintour.  I changed my 56 plate SMax for the same in the new model and wish I hadn’t.  Build quality awful.  37 dealer visits, 2 from Ford Technical and 6 months total with the dealer.   If yours works stick with it is my advice
  • Wellys and Mac
    Wellys and Mac Forum Participant Posts: 447 Participant
    edited July 2019 #11
    Latest generation auto gearboxes require a change in driving style especially when towing. Slow driving, say less than 5mph is to be avoided.
    I stopped reversing the caravan years ago because of damaged this caused to a dual mass flywheel, have a mover so I use it. Reversing a caravan is an absolute no no in my dsg book.
    As far as standard cars go, above a certain torque you get a wet clutch.
    You must have the gearbox oil changed, no getting round it. Mine is at 38k miles. But because I tow around 3k a year mine is being changed at 30k miles or third service which ever is sooner. I highly recommend if you go auto you do the same.
    Last week I picked up my now exactly 1 year old new to me car. I dont care about its towing abilities, it was bought purely to put some sparkle back into driving, its petrol too, so that confirms it.
    Dsg and towing? Last weekend, 1500kg caravan, 400 miles spread over 2 days, into Cornwall, hills and all, what caravan? Superb. (190bhp engine)
    I'll never go back to manual, DSG is that good. Having said that, Michelle has an A3 Cabriolet, manual diesel, she wont go auto,  so it depends on the individual.
    Test drive one.
  • DougS
    DougS Forum Participant Posts: 327 Participant
    edited July 2019 #12
    As you've said it, we can agree that it's a great "step in" car with loads of space and options and does everything we want from carrying 7 to washing machines to towing with plenty of space for everything and then some! ;-) )
    We have 11 plate 163 S-Max Powershift (wet clutches) with 80 000 miles. Only lower power Focus etc used the very troublesome dry clutches?)
    Only real problem so far has been DPF vapouriser plug.
    No problems with gearbox so far but we have had 2 dealer oil changes at £200 each. The Ford oil is expensive but have found compatible oil and filter set for £70 and it does need to be done carefully but it ain't rocket science.
    I'm changing it at 2 1/2 yrs and may change every 2 years in future.
  • Phishing
    250 Likes 500 Comments
    edited July 2019 #13
    Its a really good tug, no issues towing, if anything a bit soft in the rear springs but nothing to worry about.
    The wet DSG boxes are fine and will be reliable if serviced in ;line with handbook.
  • G Cherokee
    G Cherokee Forum Participant Posts: 402 Participant
    edited July 2019 #14
    We tow with a 65 plate Kuga (180ps) with the powershift autobox.
    No problems, a joy to drive, pulls our Swift 580 without issue 32mpg on the motorway.
    The only thing in the Kuga`s favour (for towing) is the AWD system
