Temperature of hot water at the washing up sinks
Justus2
edited June 2019 in UK Campsites & Touring #1
As an occasional user of onsite washing up facilities, I have noticed over time, that in many cases thermostatic valves have been fitted under each washing up sink which bleeds cold water into each hot tap and reduces the water temperature to a " safe " level. These devices can also be seen in schools & hospitals etc to prevent injury and indeed possible litigation under the guise of health and safety legislation. However, the effect of this temperature reduction in my opinion, renders the hot water, lukewarm in many cases, unfit for the purpose of washing up.
Consider a greasy frying pan, will lukewarm water actually do the job ?
Consider knives or a chopping board used for cutting raw meat, will hot water, cool enough to hold your hand under, make any impact in removing bacteria, or will it simply contaminate the whole sink for users later in the day ?
I can understand the H&S angle, but we are adults here in the main, and is the "safe" lukewarm water actually making it worse in respect of preventing the potential spread of salmonella etc. ?
    edited June 2019 #2
    I have not used the onsite dish wash facilities for over 7 years. I seem to remember it being piping hot when run. Do the still have a notice up warning of very hot water?
  • Justus2
    edited June 2019 #3
    They do, but by and large the water is far from very hot.
    The yellow label should perhaps read : Caution, hot water NOT very hot !!
  • JillwithaJay
    edited June 2019 #4
    I don't often use the site facilities but, if I've got a greasy grill pan for example, I find it more convenient to do that in a 'big sink'.  I've never had any issue with the water not being hot enough for such a job.
  • RedKite
    RedKite Forum Participant Trusted Posts: 1,935
    1,000 Likes 1000 Comments Name Dropper Photogenic
    edited June 2019 #5
    Did not notice any difference last year and we did a few sites it was always to hot and thought the it was only showers and hand washing sinks had the controls on as we did not see any on the ones last year perhaps they have been changed for this year. I used to work with Adults with learning difficulties in gardening and then catering and we had to make sure they did not scold themselves again H&S but it was in an older building and now gone to make way for a new Aldi.
  • Justus2
    edited June 2019 #6
    We do exactly the same as you Jill, and I expect it depends which sites you visit. Some have had thermostatic valves fitted, others not...( yet ? ) Some that spring to mind where we found cooler hot water were Balbirnie Park and Poolsbrook ... Others too so far this year but it may have been Moreton in Marsh or Bladon Chains, I really can't remember, but I am noticing a trend, and if you look under the sinks if the water isn't very hot, there sits a thermostatic valve...undecided
  • JollyKernow
    edited June 2019 #7
    Morning
    Thermostatic mixing valves have a set temperature range. This range is decided annually by a third party company (on club sites). This year the range is between 39 and 43 degrees centigrade. Whether that is hot enough for your dishes is for you to decide. I think it has been decided that tmv's are only necessary in vulnerable areas, so I can see as a tmv becomes faulty it won't be replaced. The outlet temperature of a non tmv outlet will then be as it comes from the calorifier ie VERY hot.
    JK
    edited June 2019 #8
    When I was working ,one of our company scientists ,was questioned  about water temperature and use of soaps and washing up liquids and he advised that they are effective even in almost cold water, as the "chemical"  make up in all except the very mild soaps are designed to work at low temperatures it just needs you to use more as the temperature gets lowersurprised
     Ps   the water at clumber park is too hot?in the washing up and laundry sinks the cautionary signs are neededwink
    edited June 2019 #9
    The clue will be when it says HOT on the tap or the top is red then. 🙄
    edited June 2019 #10
     ... and yet the hand wash basins in the shower blocks always seem to be 2 separate taps where the hot water is hot enough to scald
  • Justus2
    edited June 2019 #11
    Hand wash basins perhaps do need cooler hot water, but in respect of washing up sinks, I don't have a problem with water that is too hot... I can add cold to suit. But water that isn't hot enough is, in my opinion, useless for washing up greasy pans or utensils used for raw meat and you can't make it hotter..
    However, JK has kindly provided a temperature range above for what the hot water should be, if a sink has a valve fitted, and it is working... roughly 40 deg C.
  • JollyKernow
    edited June 2019 #12
    Hi
    Every hot tap be it with a tmv or not will have a yellow caution sticker next to it.
    If a tmv is faulty 9 times out of ten it will run cold rather than hot. We've just done a fail test on all our tmv outlets and surprisingly they all worked. I've worked on other sites where that was the opposite!
    As JV mentions above, modern day detergents work at a low temperature, but I sort of agree that red hot water cuts through that greasy pansmile. Having worked many years in the food industry I always wash everything twice, part of nvq training.yell
    Anyway, this afternoons job is...….yep, testing water temps. We do that on a monthly basis on hot and cold outlets for the prevention of Legionella bacteria
    JK
  • rayjsj
    rayjsj Club Member Posts: 932
    250 Likes 500 Comments
    edited June 2019 #13
    The phrase 'please move me, i am burning' comes to mind. If a tap has a red indicator....expect it to be hot, if a blue indicator, expect it to be cold. Perhaps a Brail indicator for blind people ? apart from that.You cannot create a sign for Stupid.
    DavidKlyne Club Member Posts: 14,801
    edited June 2019 #14
    Why don't they use mixer taps so that the user could self regulate the temperature?
  • KeefySher
    edited June 2019 #15
    Hot is on the left, cold on the right is the standard for plumbing installations be that single taps in pairs or mixer taps.
    edited June 2019 #16
    but they wouldn't stop someone from just turning the hot tap on ...
  • flatcoat
    edited June 2019 #17
    If the temp is too low there is a risk of legionnaires disease spreading...  however i agree on the very rare occasions we use the BBQ and wash it at the kitchen i find the water is not hot enough to cut the grease. At home i pour a kettle of boiling water over to help degrease and kill the bugs....
  • KeefySher
    edited June 2019 #18
    Sacrilige... only clean the Cadac once a year tongue-out it gets hot enough when its in use
  • Oneputt
    Oneputt Club Member Posts: 9,240
    edited June 2019 #19
    I suppose if your a tenter it could be a problem but as nearly all LV have there own washing up facilities I can’t see a particular issue
  • ABM
    edited June 2019 #20
    If you are on a site for while & the facilities are none too hot then just take a lecky kettle, boil it & top up as required ( assuming there is a 13 amp socket available of course )
  • Justus2
    edited June 2019 #21
    Indeed we do have our own facilities and most of the time use them. But when we have a lot of washing up, or have particularly dirty or large items it is sometimes easier to go off to the facilities. For me, this is the very reason they exist, otherwise why have them in the first place ? What I find irritating, perhaps even insulting is that having trundled across to the block, I sometimes find that the hot water temperature has been deliberately limited to a level predetermined by someone somewhere sitting at a desk, on the off chance that I may not have encountered hot water previously and know that perhaps adding a bit of cold may be needed to achieve a temperature of my choosing...... yell
