Chausson Titanium 640 fresh water drainage
wanderers
wanderers Club Member Posts: 19
edited May 2019 in Motorhomes #1
Just bought our Titanium,very pleased with it ,but how do people drain the fresh water tank if needed before travelling.There is a drain point under the van but this entails a bit of crawling underneath !.Or do people just let it go into the waste tank,( much easier to empty )
  • beero
    beero Forum Participant Posts: 38 Participant
    edited May 2019 #2
    I don't drain fresh water before travelling, does anyone? I try to judge my top ups so I am not travelling with a full tank for obvious reasons but I may need some water to wash up if I stop for a cuppa en route.
    Tinwheeler Forum Participant Trusted Posts: 24,227
    edited May 2019 #3
    We don’t drain the fresh tank unless the van is going to be unused for a while but, when we do, the tap is easily accessible.
    Perhaps you can reroute the pipework so the tap is easy to reach but why drain it just for travelling unless your payload is ultra critical. We often travel with the tank full if we ‘do’ the tanks as we leave a site. It’s surely what MHs are built to do.
    SteveL Club Member Posts: 12,546
    edited May 2019 #4
    We recently bought a Hymer. This has a easily accessible drain tap located within the van. The tap has a closed, open and 20 litre position. For traveling we try and end up with 20 litres left and open the tap to this position, so far only a few drips have come out, so we have gauged it about right. If it didn't have the 20 litre left position, l guess we would just try and end up with that amount anyway.
    edited May 2019 #5
    Happiness is a full tank. I don't know whether it is a relic from my sailing days but I like to keep my fresh water tank topped up as one never knows when you will be able to get some more. We got caught out on an aire in Normandy on our way home where the water supply was not working. Had to buy a six pack of mineral water to keep us going till the ferry.
    edited May 2019 #6
  • ABM
    edited May 2019 #7
    Surely there is guidance on this in the HandBook undecided
    Cornersteady Club Member Posts: 15,416
    edited May 2019 #8
    yes same with me with fuel (especially when towing) as we were taught:
    the only time you can have too much fuel is when you're on fire
  • Cybil 666
    Cybil 666 Forum Participant Posts: 10 Participant
    edited May 2019 #9
    Whe i picked up my 640 i was told you cant drain it apart from running the taps, i cant see a valve underneath either, having said that I havent taken of the large tank cap to look inside. You might want to have a look at this thread wanderer and save yourself the hassle of holding the pipe when filling the tank up
    Andy
    https://forums.outandaboutlive.co.uk/forums/Motorhomes/Motorhome-Matters/chausson-technibox-water-filler-cap/51391/
    edited May 2019 #10
