Water inlet HELP...
Chris516
Chris516 Forum Participant Posts: 1 Participant
edited April 2019 in Caravans #1
Hello, I’m new to caravanning and have a lunar premier 516 1993. I am updating a few bits and one in the list Is the water inlet. It has the external pump and the clips have broken etc. What would be a good substitute for the pump and wall plate etc.
  • markflip
    edited April 2019 #2
    If it's a whale Watermaster system (which I think it will be given the age of the van) all the bits are available from many suppliers, including online sites, the 'socket'/wall plate is about 25 quid I think (there are some variants depending on the system and whether the taps have microswitches or if there's an inline pressure switch) and a new pump assembly is about £50 (I've just had to buy one).
    wallplate assembly is part number
    ES1000 for microswitch systems
    ES1001 for pressure switch
    pump assembly is EP1612
