Lunar Delta RS 2012 - Solar Connection?
Puffernutter
Puffernutter Forum Participant Posts: 14 Participant
edited April 2019 in Caravans #1
Just swapped a soggy Sterling for what I hope will be a dry Lunar!  It is a Lunar Delta RS (2012) and as it has an alarm and a tracker it is importunate I keep the battery topped up!
It is in storage, so I'll be using a solar panel. The Sterling had its faults (quite a few in fact!) but it did have a pair of wires I could connect the solar charger to!
I've had a look at the Lunar Delta wiring diagram and whilst  am used to Haynes Manuals and French cars, this even beats those for a total lack of readability!!!
Does anyone know if there is a pair of wires I can use for the solar charger, or do I have to look to connect direct to the battery?
Cheers
Peter
  • dave the rave
    edited April 2019 #2
     as far as I can recall........connect to battery via fuse and controller
    edited April 2019 #3
    had a delta RI 2016 and had wires behind the panel where the power socket and light switch are to the left side of the kitchen worktop.
  • Puffernutter
    edited April 2019 #4
    All, thanks for the helpful replies. I'll let you know how I get on
