Is my Truma Solar Battery Charger overcharging?
ClubMemberD41A2DB66C
ClubMemberD41A2DB66C Forum Participant Posts: 10 Participant
edited March 2019 in Parts & Accessories #1
My latest Coachman VIP 2019 has a Truma Solar Dual Battery Charger 100w system fitted.
The Coachman display panel only indicates the leisure battery overall voltage not charge, or so I believe?
It's feeding a 120w sealed wet battery and it is in store. My concern is safety and fire risk?
One the first month of ownership I have noticed the leisure battery voltage grow from 13.4 volt to as of today (Overcast) 15 volts, which I have never seen before on any of my caravans or campers?
The the tempriture probe has not been fitted but the battery dose not feel warm.
The Coachman gauge is showing 15 volt with the warning of overcharge and contact your dealer it it continues? Which i am trying to do with little success to date. The voltage range is in the manual shown as 8 - 15 V but the charging for a wet battery is shown as Absorbtion range 14.6 V Float 13.8 and Equalisation 14.8 V with a Maximum charging voltage of 16.6 V
Should I be concerned this will either damage the battery and or cause a fire risk from overcharging?
Thanks Peter
  • ocsid
    edited March 2019 #2
    If not done already I would check the precision of the quoted voltage readings with a decent multimeter, just to be confident they are real as here the small magnitude difference make accuracy important.
    Just thinking aloud how I might approach this myself, you obviously are aware of what you ought to be seeing:
    If the equalisation level persists along with a current longer than about two hours, happening periodically say monthly, then it is not good news, it is too high long term.
    However, after being driven up there by a current, when that current is removed, it might possibly linger as a surface charge, so before worrying just put a few lights on for 5 minutes, then check if it returns to sensible levels after that load is removed.
